Cruise control does not work after conversion
NJMike
60+ Posts
Aug 30, 2023
112
169
Hackettstown, NJ
Mike
First, let me say that my problem could be entirely coincidental that the cruise control on my 2021 GW DCT Tour has stopped working correctly after the CSC conversion. Having said that…
The cruise control has worked for over two years without a single malfunction. So it seems like a possibility that a major change to a trike may have caused the issue.
The cruise control system can be turned on and off normally. But it disengages at random times and road conditions, i.e. uphill, downhill, level. The “system” stays on but disengages. I can usually resume but sometimes I cannot either resume or set.
There is also a “scratchy” or “staticky” sound coming from the right rear light area when the foot brake is depressed just enough to trigger the brake lights. The brake lights flicker in sync with this sound. If I depress the brake further the sound stops and the lights are normal. This sound does not occur on the left side nor does it occur when the front hand brake is used.
I am in communication with Will on the problem. Anyone have this happen after your CSC conversion and if so, what did you do?
Thanks,
Mike
Thanks,
Mike
If the brake light flickers or goes on and off that will disengage the cruise control.. sounds like there’s a loose wire somewhere???
You might want to try adjusting this rear brake switch position for correct engagement.
My wife followed me in her car. The cruise control disengaged twice in the first 5 miles. Both times she saw the brake lights flicker. Of course, I did not hit the brakes. So does this mean I should adjust that microswitch?
Yes..........
That would be a good starting point
It’s easy to adjust that switch. But I wasn’t able to accomplish anything in the garage. The right rear light still makes the scratchy sound regardless of where I adjusted the brake switch. The right rear light assembly isn’t the problem, because if it was it would make the same scratchy sound when the front brake lever was pulled. I want to say that maybe that rear brake switch is bad…but why would that go bad because of the trike conversion. It worked fine before the conversion. I am assuming that since the “scratchy” sound remains that it still isn’t fixed. But I can’t know that for sure without test riding.
Can that rear brake microswitch be removed and cleaned? It looks like I’d have to remove the plastic cover (2 screws) and then there’s a “lock wire” that holds the switch to the plug.
I want to say that maybe that rear brake switch is bad…but why would that go bad because of the trike conversion. It worked fine before the conversion. I am assuming that since the “scratchy” sound remains that it still isn’t fixed. But I can’t know that for sure without test riding. Can that rear brake microswitch be removed and cleaned? It looks like I’d have to remove the plastic cover (2 screws) and then there’s a “lock wire” that holds the switch to the plug.
Mike,
The only ocassion where I have experianced the issue you described was corrected by adjusting the rear brake microswitch, but there may be some other cause.
I'm not understanding the "scratchy sound" coming from the light. Anyone have any thoughts on that issue?
I adjusted the brake switch, went on a 40 mile ride and it worked perfectly! I intentionally loosened the switch, probably more than I needed to, and will tighten it back up a little at a time and test ride.
Good to hear that fixed it for you.
One last post on this thread - thanks to all of you who made suggestions that led me down the path to fixing my issue! Looking forward to being a long time member!
This is indeed a great forum - folks are willing to provide lots of help.
Enjoy your ride - and post a few pictures when you can
I would like to post pics but again, I have no icons allowing me to add pics or anything else.
I use Imgur - free photos. Put your pictures there. Once there, open the file and use post to message boards.
This works well for me.
Bullet Proof
