2016 Freewheeler gas leak
Jun 11, 2023
1
1
El Paso
I have a gas leak coming form the down tube where the gas gauge wiring feeds through, does anyone know about this issue on a 2016 HD Freewheeler.
Joel......Welcome to Trike-Talk.....:wave4::wave4:....If you post this again on the Harley Forum you'll get better info there....Again Welcome....:wave4:..
Hi Joel, :welcome: to Trike Talk and your first post
Are you sure where the gas ls leaking ?
The tube the wires run up into is sealed off from the tank and cannot leak unless there is structural damage
Have you done any work on or around the gas tank?
Check the quick disconnect on the fuel line, they are a known leak if the line has been removed and put back on too many times or by force
Stop by the New Members area and introduce yourself and your trike
You may want to start a new thread in the Freewheeler Forum for more views by members
