Fixed my "non-start in gear" issue...
Mar 16, 2022
4
10
Smithfield, Maine USA
I've had an issue with my 2015 TriGlide not starting in gear. Replaced the switch thinking it was bad but it still wouldn't start (in gear). Tore into it again to make sure I hadn't pinched a wire; carefully put it back together and still no luck. So, as I was sitting on the bike I happened to be resting my foot on the rear brake pedal when I tried to start it again....guess what....it started. I tried it several more times; foot on the brake, front brake lever depressed, both brakes applied,,, worked every time. Now, I'm p***ed...because nowhere in the owner's manual, shop manual or instructions (included with the new switch), does it say to apply brakes when trying to start the bike in gear. But now I can sleep at night and not rack my brain trying to figure it out. Thanks for listening; ...I feel better now. LOL
I’ll bet it will also start in gear just holding the brake lever on the bars…👍
Either front brake or rear brake will start in gear with clutch in, the front brake seems to need more pressure than the rear
HD has tons of problems with the earlier LH switch pak, the cure there was a new switch pak with the updated clutch lever
I am pretty sure my 15 FLRT (Freewheeler Trike) owners manual stated the starting in gear procedure
From my many years experience with bikes, trikes ATC’s ATVs It’s been ingrained on me to never try to start any of them in gear or even in neutral, without my foot firmly on one brake and hand on the clutch lever especially if you have a bike that has clutch lurch (Sticking clutch plates when cold)……..
