Front tire question
Mar 23, 2023
2
7
Citrus Springs
Just purchased a 2013 tri glide-it has a 130/60B 19 on the front-looking at original tire specs and it shows a MTB90 16.
Anyone have thoughts on if this is ok or should I go back to original tire?
Welcome to Tike Talk.
Sounds like you may have the Enforcer wheels on it. Stock is 16 and The enforcer wheel is 19. You should be good to go.
Yep the front tire/rim were changed possibly. You can even put a 21in under the stock fender. It changes the weight distribution by lifting the front so the steering is a little lighter. The profile is changed with the front being a little higher. I road with a 21 on the front of my 2013 TRI for 7 years and 60k miles and loved the look and the handling.
The CVO trikes have the taller front wheel on them.
