Vehicle Information Switch
2018 Tri Glide. After hitting the Vehicle Information switch the Vehicle Status screen shows a line for "oil pressure". Mine is showing "check oil". The oil level is correct (checked hot) and only a few hundred miles since the last dealer oil change. Any suggestions?
It’s just A reminder….like my clothes dryer a light flashes check filter before I press the start button..
I had a 2018 TG as did a friend. During a road trip his bike did the same thing and his oil was full. Rode on with no problem. A few months later mine also did the same thing. New oil pressure switch fixed the problem on them both.
My 2017 TG failed to show oil pressure OK on the dash idiot light a few times over the past few years. Shutting it down and restarting always corrects it. Never heard any engine noises when this happened. Suspect that an oil pressure switch replacement would make this go away, but it has been very sporadic and limited (only 3 or 4 times in a couple years). Guess I would rather see it not indicate oil pressure when there was, than indicate pressure when there wasn't.
Trike#1
