Rear shocks on 2009 Stallion
Jul 28, 2022
2
Green valley
I have a 2009 Stallion and wanting to know how to smooth out the ride especially for the passenger. No matter what I set the air adjust the ride is still like a tank. When I looked under the rear end I found 2 independent adjustable shocks but not the air adjustable shock. Where is it? Anyone have the same issue or are we the only ones. I really need to get a smoother ride or my wife won't ride any more, driving or riding.
Jerry.. Welcome to Trike Talk..👍👍.. check the air pressure in your rear tires might be over Inflated….
Welcome Jerry. I run my front tire at 40-41psi and my rear tires at 25-27psi. I set the air bags at 20psi and if I have the trailer on at 25psi. You do not have air shocks on the back, only air bags. The compressor, located behind the rear backrest, should automatically pump up the air bags to about 15psi when you turn on the ignition. Rick
On the adjustable shock, you should have received a cam wrench to adjust the shock. I would set it to the lowest setting and try that. It may already be set on the hardest setting???!!!
Bullet Proof
