gear lube for differ
I shoot grease into the grease jirks every season.......... I have two grease jirks on the drive shaft, so beginning of every season I grab my trusty grease gun and pump away till I see a bead of grease ooooze out of the ends, than I'm all set for the season......
As for a way to lift up your trike, look for my post on how to "make a lift cheap" Hey it works!!!
Ronnie
7/17/22
Per CSC 2017 Owners Documentation/Manual
The 2017 manual states: "Use only NON-synthetic 80W-90 GL-5 gear oil. Change after the first 3 months or 3,000 miles, whichever comes first. Rear end oil should then be changed every 12 months or 20,000 miles. The differential case should contain no more than 1qt of gear oil.
i believe this is for a mc final drive and the question was for a trike differential
bk65
