Anyone use this product or something similar to tie down the rear of their Trike?
https://ericksonmfg.com/product/wheel-chock-and-strap-kit/
Those wheels on the side by are clear of the fenders but with a Tri-Glide I don’t think you can get the straps around the tires with out damage to the fenders?
The way the fenders are on a Tri-Glide you’re probably right this setup wouldn’t likely work.
However on a Freewheeler which is what I’m tying down the fenders flare out in the back so access shouldn’t be an issue.
Free wheeler or triglide it definitely won’t work on the front tire don’t know about the free wheels but tri-glides come with tiedowns on the back axle,..
Owner's manual is the same for Freewheeler and for TriGlide:
2021 HARLEY-DAVIDSON® OWNER'S MANUAL: TRIKE MODELS
The rear axle has steel loops on the bottom (left and right sides) which may be used to tie down the rear end of the vehicle when transporting on a trailer.
When I was trailering my Can am one of the straps came off . So check the tie down straps a lot.
