Champion Trike Hitch wiring
Apr 26, 2014
38
5
Woodland Park, CO
I have had my 2009 IRS Champion for 2 years and decided to borrow a trailer for a trip. I went to plug the trailer wiring into the hitch's wiring and couldn't locate the hitch's wiring harness. I was told the Champion kit came from the factory with the wiring harness but I have looked carefully under the trike's trunk thinking it was tied up high under the receiver hitch but cannot locate it. I pried up the carpeting in the trunk and couldn't find it there either. (P.S. the original owner had not used the hitch previously).
For those with a Champion kit, any idea on where the hitch's wiring harness might be hidden or how I should go about tracing it??
Thanks!
The harness extension is usually located under the body at the back edge of the trunk floor. You will have to look w/mirror or light. The harness is held in place by clips and usually runs from the left to the right. Wire ends are usually heat-shrinked. It may have been partially glued into place. Unless cut off by installer, it should be there.
Jim, thanks very much for the hint on where to look. I think my problem was I was looking for a wiring bundle that had a plug on it. Instead I found a wire bundle with the ends heat shrinked (on the right side underneath) and held tight to the frame with wax and a frame clip about 4 inches to the left ...just as you predicted!
Question: what type of plug end does Champion normally install, given it looks like the wire bundle contains 5 or 6 wires.
I did find a Champion trike maintenance sheet that says the wiring of the trunk contains 6 wires so I am assuming that is what I will find once I pull the wire bundle off the frame.
I really appreciate you help and time on this....I doubt if I would have found the wiring bundle because I just assumed there would be a plug on the end!.
Thx, Keith
They usually use a 6 pin weather proof metal receiver. But it really depends on the trailer you use on what configuration and what end you sue. I usually use a flat five connector for a five wire trailer. One of those wires is a battery wire for inside trailer accessories like a cell phone charging station or access lighting.
I just found this old thread and hope someone here might see it.
I have an '06 Champion trike on a '06 VTX1800C. It has never pulled a trailer to my knowledge.
I am trying to connect a trailer' and found the harness mentioned above.
This harness has 6 wires.
Red
Black
Yellow
Green
Blue
Brown
Can anyone here tell me which wire is which ?
Red
Black
Yellow
Green
Blue
Brown
The following is from the Champion installation book.
Running Lights - Brown
Brake Lights - Red
Right turn - Green
Left turn - Yellow
Accessory (12v+) Blue
Ground - Black
Tozbro
