How much more comfy would my trike be if i put only 22 lbs in rear tires???
B
Burnerboy
I 've been reading much about putting in only 22 lbs in my rear tires, for a smoother ride, instead of the much higher recommended amounts suggested by my trike builder..
My ride is not as smooth as I had hoped, before triking........
2010 Honda Goldwing/Roadsmith model
Won't this lower pressure wear out my rears faster???
I ride "both" back roads as well as highway riding (70 MPH ish)
I am not a cowboy with my trike, (I baby it) I ride the speed limit, and enjoy a relaxing ride......... BUT I do many long distance trips.....
Ronnie
Ronnie
You'll never know till you try it...:Shrug:.
Ronnie
Ronnie, I have been riding the VTX you saw me with for over 6 years with 20# air in the rear and 40 in the front. That recommendation came from experts right here on Trike Talk. You are not carrying the weight of a car with you. My tires wore perfectly. I just replaced them a month before I sold it. Don't remember the date codes. I personally put 25,000 on them. Don't know how old they were. Could have been original tires. It had 58,000 on it when I sold it. I did put a BT45 on the front and ran it backwards. It was still going at 28,000 miles.
bt
22 LBS in rear will be tried............I'll report back in a few days, after reducing the lbs in rear's
Thanks all
Ronnie
Well, since I reduced the tire pressure to #22 lbs all it's done was too rain everyday (or so hot 95*+) that I have not even touched my bike....I'll soon check it out (but it's pouring rain again today)
Well guys,
I finely had a good chance to ride my newly lowered tire pressure (22lbs) a good long distance.... and I took it on a long ride to the Vermont area (now be advised, too, those that don't know these back roads, in Vermont, I can tell you that some of these roads are so bad that it would "jarrr" your back teeth.....BUT these roads are also long, sweeping, no traffic, wind'ie bike perfect roads...
I went a total of 189.6 miles Round trip from my home.... Vermont border is 60 miles from my front door......Anyway I LOVE THE TIRE PRESSURE LOWERED DOWN TOO 22LBS., I FOUND THE RIDE SO MUCH SMOOTHER...................SO THANK YOU TOO ALL THAT RECOMMENDED ME TOO LOWER THE REAR AIR PRESSURE...........It's now a pressure to ride my trike again..
:banana-pair::bass::pinkpachy::whistling::whistling:
Ronnie
Not if your running a rear tire on the front. The majority of the trike crowd from right here on the forum over the last 8 years or so agree with 41 and running it backwards. I wonder what Poppa Zook's take on this is?
Don't know who started the 40/41 stuff or why it took hold but, for me I also started with 41 in a reversed BT45 on the front of my Wing trike. Never had such a hard ride, All most like the front forks were solid rods!!!! Lowered pressure to 36. What a difference.
I encourage you give it a try.
Well guys,
Ronnie
Atta boy Ronnie!!!! :clapping:
Thank you for the email on lowering the tire pressures...:hooray:
Yep I'm totally impressed with the 22lbs now in my rear tires......much smoother, NO MORE :biglol::biglol: like I had before I DEflated them
Ronnie
22 lbs in the rear, 36 front 2021 Triglide + happy rider
Once I read this forum I dropped my pressure from 26 to 22 in the rear tires on my 2021 Triglide and it made a world of difference. Then I added the Legends Lift Kit and it rides 100 times better. I'm still thinking shocks because we have terrible roads here, but the lower pressure and lift kit made a world of difference.
I don't understand why you have to REVERSE the rotation, and mount the BT tire backwards...... :mega-shock: What's the reason????
Ronnie
Good for you to actually give it a try in the real world—way better than talking about it.
I run 22 rear and 36 front on my RS Wing. Shocks are full soft, larger diameter anti-roll bar comes on as early as possible. EZSteer with firmer front springs up front. Very plush. Very sporty.
Ronnie
I had the BT45 on the front of my Gold Wing in forward position. Cold psi was 36. It wore beautifully and never had a problem with grip when riding in the rain.
It is a popular statement among trikers to run this tire in reverse… I never understood why and didn’t see the logic of doing so.
Also had Ride-On in the tire..as well as the other 2 tires.
I don’t know what the reasoning is to run it in reverse position. :Shrug:
The stress on a rear motorcycle tire comes from acceleration. A rear tire is manufactured so the tire overlapping accommodates that stress. Conversely, the stress on a front motorcycle tire comes from braking and it is manufactured with those stresses in mind. So, if you mount a rear tire on the front of a motorcycle without reversing it, that tire will experience stresses that are opposite of what it was manufactured for. Probably not something that will be noticed by most of us recreational riders..... Jim
I have to say that I "totally baby" my trike, and ride it like it's brand new every ride...............I use the brakes little as possible (if I know that I have to stop, up the road, I just cruise to the light or stop sign, and let the bike slow down w/o using the brakes.... (it's a game that I play, with myself.."is to use the brakes little as possible") and never "REDLINE" the engine... hey it's going to be the last motorcycle that I'll probably ever buy (71 yrs old now) why wear out the brakes if I don't have too...............
Ronnie
By the way we are just kidding with ya. Treat your trike right and it will treat you right. Don't need to stop hard if a slow easy stop works just as well. Anticipation and defensive riding are a good thing.
Automatic Transmissions are the best money maker for the brake repair shops....
Run right up to a red light and hit the brakes...Riding down a long incline' Ride the brakes all the way..:gah:...Anticipation' No way...
Thank you Jim,
I do ride my trike, like it's the first day I purchased it,/ I never hot rod, around town / never "red line" it / or go above the speed limit (well maybe in the twesties/once in a while) lol
Ronnie
