Over tightened rear lug nuts
dthorn
40+ Posts
Aug 26, 2020
37
48
Thornell, MI
David
Hi all
I was checking the torque on the rear lug nuts. I thought I had set it at 100lbs. As i was putting the torgue wrench in its case I noticed I had set it to 110lbs. I went back and loosened the nuts and set them to 98lbs. I know that 10lbs is not that much, but they are made from aluminum. Do you think that I could have damaged them ie: stretched or cracked them.
I have read stories where wheels have come off/almost come off while riding. One guy found two lug nuts loose. Both had be cracked by over tightening. I know I sound a little paranoid, bot having a wheel fall off while going down the rode would defiantly run your day
David
I would have no problem at 110. Aluminum wheels tend to get a little loose, our local dodge dealer recommended that for our Nitro wheels that should not be an issues. Fred
Hi all
Hopefully your set the torque wrench at its lowest setting before you put it away. Leaving it set on an upper end torque will make the torque calibration off.
The only times i broke wheel studs was at the Drag stop changing tires in a hurry....
And that was on my 68 Charger.....Back then Chrysler thought it a safety thing to make the right side wheels left hand nuts.....So they were Righty-Loosy....Lefty Tighty.....
:gah:.....
Hi Koolbreeze
I always loosen all my torque wrenches back to lowest setting before putting them away
I've got a split beam torque wrench. You never have to back off the setting when you put it away. And it clicks when it's torqued. So I don't have to stand on my head to read it.
I Don't need no stinking torque wench.....All i do is tighten till it strips..And then back off a 1/4 inch...;)...
