Primary Oil leak
I have a 2012 Triglide that I purchased 2 years ago with 9500 miles on it. Ever since I’ve owned it she’s been leaking primary fluid. I changed the drain plug and O-ring, Derby cover casket and finally the outer Primary gasket. I’m left with the inner Primary gasket. Am I missing anything????
welcome paul where exactly does it look like it is leaking from? there is also a couple of inner seals crank and trans shafts
Welcome to the forum!
If you look at the back end of your shift rod, it is attached to a lever. Look down the hole that the lever goes into. It is not uncommon for a leak to develop in the seal around the shaft that that lever is on.
