head pipe
Jan 21, 2009
1,144
812
MA
Dan
I took the connector pipe that goes from the head pipe to the muffler and replace it with a 2.5"piece of stainless steel flex pipe , I cut 1.5" of the end of the head pipe cut about 3 " off the muffler welded in a piece of 2.5" pipe connected it together, work's good no clearance problem the trike sounds so much better is so much cooler.
The original connector pipe goes from 2.5" to 1.5 inside diameter, the exhaust is just stuck there trying to get out . never found any body to do a tune I got a tune from Dyno Jet Then did 4 auto tune's it runs good now, spark plugs have a nice light tan color, ended up wit a 128 11.1 compression screamin eagle head's screamin eagle 64mm throttle body 5.5 injector's redshift 472 cam stock gutted head pipe wrapped the exhaust S&S race muffler's .
there's a swap meet coming up in april if the dyno guy is there I will get a dyno run to see what the torque is ? it is rideable at all speeds the woods 408 cam does not work in a trike! The power is crazzy , getting around 30mpg Now Im HAPPY I will try to post some pictures this week end .
Very interesting. Slide your phone under there and get a picture for us.
By the way, I believe Wilkins Harley in Barre Vt has a trike Dyno.
I took the connector pipe that goes from the head pipe to the muffler and replace it with a 2.5"piece of stainless steel flex pipe , I cut 1.5" of the end of the head pipe cut about 3 " off the muffler welded in a piece of 2.5" pipe connected it together, work's good no clearance problem the trike sounds so much better is so much cooler. The original connector pipe goes from 2.5" to 1.5 inside diameter, the exhaust is just stuck there trying to get out . never found any body to do a tune I got a tune from Dyno Jet Then did 4 auto tune's it runs good now, spark plugs have a nice light tan color, ended up wit a 128 11.1 compression screamin eagle head's screamin eagle 64mm throttle body 5.5 injector's redshift 472 cam stock gutted head pipe wrapped the exhaust S&S race muffler's . there's a swap meet coming up in april if the dyno guy is there I will get a dyno run to see what the torque is ? it is rideable at all speeds the woods 408 cam does not work in a trike! The power is crazzy , getting around 30mpg Now Im HAPPY I will try to post some pictures this week end .
would like to see the Dyna. Be Safe BK
I no John pretty good up there . They do but wont do it with the power vision , they want me buy a TTS tuner and there auto tune probally another $ 1500. - 1800. with tune. I put 225 miles on today did some more auto tune's run's really good, last tank I got 31 mpg. From 1500 rpm it pull's really strong a lot of fun I have to stop beating it . :D:D:D:D:D:D pretty good
I will get a picture , I cant believe nobody has made a pipe to replace that one yet , I think all the exhaust maker's feel there's no money in making trike exhaust , I went to a friends shop he make's car exhaust we could not get tight enough bend to get the pipe high enough line up with the muffler, we ordered a bunch of elbow's to try to make one welded together rather than flex pipe ? Maybe my good friend Kevin could manufacture one ? I'M sure if somebody made them they could sell a lot of them ?
Looking forward to the photos. Sounds really interesting. I am getting close to making a decision on changing my exhaust, and while doing that, what you describe may be something to do at the same time.
Have them just do a couple of runs to show hp/tq and afr, no tuning. That's easy for them, maybe one hour.
There about 165 miles from me ,I buy most of there take off part's . we have a swap meet coming up in April at Stafford speedway Dr Dyno will be there, I will have him Dyno it . I"m still trying to get a hold of Hulten's in N Y to do a real tune they may be gone to Daytona ?
pictures of pipe
Edited previous post and added pictures of the pipe
Nice job! I wonder how close size wise it is to the current M8 muffler inlet for the touring models. I can’t believe hd wouldn’t redesign a bigger intermediate pipe, unless they have thousands laying around to get rid of, lol.
Its the same size as the touring right hand muffler, but I cut the end off my S&S muffler and welded in a piece of 2.5" pipe , Im not a big fan of flex pipe, trying to make one up out pipe is hard to get hose close tight bends. Theres about a 1/2" space between the swing arm and the pipe , I put a flat spot on top.
Thanks for the photo's.
Are you concerned about how small the crossover is to the left side, and how small the left side connector to the slip on is?
Or are you viewing that as an overflow or relief for what is not carried out on the right side?
I took a piece of 2" pipe cut about a 1.5" long and welded it in two the cross over pipe inside to help scavage the exhaust
Its that way on all touring bikes I was concerned about the 2.5" id pipe going into 1.5/8 id ? It works for me a lot less heat and a lot better sound
I'm waiting for someone to block the crossover and smooth out the right side flow with s change in baffle to 2-1/2 or 2-3/4. This should create a 2:1......... maybe?
I believe Krome Werks, and Dragos both have option for closing off the crossover pipe, essentially turning into a 2:1 system. Dragos recommends a special muffler designed for 2:1. D&D makes a 2:1 for Harley trikes now, as well as a 2-1-2 system. I have yet to see a pic of the intermediate pipe. The intermediate pipe is a bottle neck compared to normal touring setup. Shortening the collector and using a slightly bigger pipe with less of a bend might make one an interesting experiment. You could make something up like a stepped header in reverse to step down to a current trike muffler. There are a couple of places that sell kits for making custom pipes. Just talking out loud, lol.
Good Post. The straighter the pipes AFTER the head pipe { low pressure } the faster the exhaust gas will scavenge;)
I checked out the D&D 2:1 exhaust there F ING nuts to get the complete black exhaust with the false left muffler $2152.00 plus shipping and tax . I spent $ 10.0 for the flex pipe $20.00 for two clamps
Now I want pictures of the above. :) Very interesting subject. Not something we anticipate doing as a company...but something that is tickling my thoughts personally.
Yeah, that would leave the left as a ghost pipe (for aesthetic symmetry) and if the flow was smooth (fast) you would think it would work well, like the 2 into 1's that are built from scratch and cost big $.
I have a 2020 triglide. I just looked at my pipe & measured it. It measured 1.77 outside diam. Also i don't believed it is as curved. Hard to tell laying on the floor looking at it.
Part #’s for Khrome Werks muffler with the crossover cap, 202560, and in drag 1801-1152 if this helps anybody.
Had some thoughts overnight. I like the idea of lengthening the intermediate to make the bends less severe. Although, I don’t know about going to much bigger on the pipe. I figure you can cut the pipe off the intermediate, weld on a slightly larger pre bent pipe. Trick is to mate the new pipe to the muffle for a good seal. Reducing the size of the new pipe, or maybe stretching the muffler inlet a bit, tough on the chrome though, lol. I am going to start look for a spare intermediate pipe, already have a decatted pipe waiting.
Exhaust
Be aware states that have inspection rules may not allow that flex pipe.
In my state NH flex pipes are not allowed as over time they will leak.
Just an FYI
Just an FYI
We have inspection in mass I have never had any of my bikes inspected in 48 years . Why do you think a leaky flex pipe would fail your bike ? Oh exhaust fumes in your Helmet cause brain damage ? :( I will check for leaks dont need any more brain damage :D
It looks like D&D may make a 2 1/2 inch head pipe extention I'm going to call them monday $195.00
Interesting, I would think that you would have to buy their muffler for the 2:1 system as well, and then block off the crossover pipe. I’ve looked at the aftermarket trike conversion pipes, none fit a stock headpipe. S&S makes a set for their headpipe, looks to have less severe bends which I think is the key. No matter how big the extension is the key is the baffle in the mufflers. Maybe cutting the pipe back further and running a reducer to get down to the S&S pipe size. Summit Racing has a bunch of them.
As a side note, Sheffer Performance just tuned a m8, 124” some head work etc with a stock decatted headpipe, 148 hp, 140 torque, posted on fb. I’m sure there was some left on the table, but that is pretty impressive for a stock headpipe design.
I think the stock head pipe decated is as good as many aftermarket maybe a couple horse power hear or there , the problem is the connector pipe goes from 2 1/2 to 1 5/8 I D , if buy aftermarket headpipe on a trike you still have to use your stock connector pipe. Im not interested in blocking of crossover pipe . Im going to order a D&D connector pipe , I will post a picture of it when I get one ?
