Goldwing fork extensions ?
Hello all, are the brake hoses long enough to add fork extensions without replacing them? If they need replaced, want brand have you all used.
Thanks,
Yes the brake lines are long enough. When you are reassembling the front end and before bolting on the calipers, install the front wheel, less the fender, and lower the bike so that there is enough weight on the front to compress the front forks. If you don't, you will think the brake lines aren't long enough, but they are and will have ample length for the full range of travel of the front forks. We've installed hundreds of them and all my GL1800 6 degree rake kits come with 2" extensions. We also sell them separately on our Cut N Shoot Customs website for those that may need them.
Thank you sir, you will soon see an order.
