kruze trunk lock
3W-lonerider
One of the Originals
Feb 18, 2008
379
235
Shippensburg, PA
3W-lonerider
anybody else have an issue with the csc trunk lock unlatching itself.
i can close my lower trunk and verify that it is latched. after riding awhile then stopping i walk behind the trike and the lower trunk door is unlatched.
i have checked the cable under the seat to make sure nothing is pulling on it. i have also adjusted the pin so it has to be pushed extra to shut it and there no slop in the latching assembly. its got me puzzled.
Where is the Key Fob when you are riding?
If it is in your pocket, you may be opening the trunk with you body movements. Just a thought.
I know the little buttons on my Key Fob can be sensitive.
Do you have to put 2 hands on the door, one on each side of the latch and give it a good push to latch? That is the way we were shown to do it and for the latch to be set properly when we bought our Trike.
Well apparently the latch wasn’t the only issue. After i adjusted it to get the latch from popping open going down the road the left side of the trunk door got all out of wack. Tried adjusting that but couldn’t get it right. So took it tp the dealer. They got it back where it’s supposed to be. They must’ve adjutant something I wasn’t. Not only that but i have no clue what came loose cause i checked all the bolts and they were all tight. But its good now.
All well that ends well........:clapping:....
I'm having the same problem with the trunk on my Champion conversion. I adjust it and it works for a while, then it starts right back to falling open when riding. If anyone could post up a picture or two as to where the problem might be, I sure would appreciate it! Thanks!
Bullet Proof
