Engine / Oil Temps
Sunman
900+ Posts
Gold Member
Apr 6, 2011
939
727
Bellville, TX
Danny
On my 2015 Freewheeler I have added the following to cool it down:
- Mighty Mite Love Jugs
- DK Customs tank lift
- DK Customs wind deflectors
- DK Customs remote oil filter kit and re-useable oil filter
- DK Customs high flow air filter and external breather
- Cobra 909 slip-on mufflers
- Power Vision tuner
Also have JES fork fangs which do not help with cooling but I thought most likely would hinder air flow.
A couple of days ago I made a 75 mile lunch run. Ambient air temp was 91 deg. I was running 60 MPH in 5th gear. The engine temp stayed around 250 deg. for a long time but finally maxed out at 257 deg. according to the Power Vision. When I got home the oil temp was 243 deg. according to the JES dipstick gauge.
Today I took the JES fork fangs off and made a 50 mile lunch run to see if the bike ran any cooler. Ambient air temp was 90 deg. Along the same stretch of road running 60 MPH in 5th gear the engine temp maxed out at 253 deg. When I got home the oil temp was 243 deg.
I thought removing the fork fangs would make a significant difference but it did not. I know this was not a very scientific test but I thought the results were interesting. I now have a lot more wind buffeting so I will put the fangs back on.
I would like to get the temps a little lower but the only other thing I can think of to do is add a supplemental oil cooler. Anyone got any other suggestions?
Sunman
Sunman
Have you done any autotunes with Power Vision to get it to your riding style? Secondly, may talk to fuelmoto about a different tune. Yesterday in 97 degree weather running 70 mph my engine was only running 212-214 degrees.
Thanks for the reply Pat. I have not done an auto tune but I think I am going to try that this week, and call fuelmoto.
Sunman
Sunman
Thank you very much for this information. I have been wondering if I should take mine off, but I do remember how much they help with the wind buffeting. This is scientific enough for me.
Sunman
Remember on the twin cam motors, you can get a larger oil pan & add another quart of oil to help dissapate the heat. The fan cooled oil cooler on the M8 does help, in my opinion.
Thanks. I forgot about the larger oil pan; I may need to check into one or a different oil cooler.
Sunman
Sunman
Danny, when I return home, I will let you know for sure. Here is what I have so far. Hd oil & filter. 90* 2000 mileage, oil filter 211 frt cyl 225 rear 250
Liqui Moly oil K&N filter 100 * 4800 mileage oil filter 170 frtcyl 176 rear 189 10w60
Miles is total on bike Do some searching on the oil. . I have been reading on it for some time & liked what I saw. Very reasonable on Amazon & I understand some Wally Worlds sell it in store. O yeah I no longer have the Love Jugs on. LOL ,let the flaming begin
I recently changed oil on my 17 Freewheeler using the NEW longer HD filter
The first thing I found is I can now run 4 1/2 quarts of oil with the longer filter while keeping the oil level on the stick 1/2 way in the cross hatched area. Also according to my PV gauge my ET is down another 20 degrees. So far so good with the new improved M8 filter. I will keep a close eye and ear on this over the next 2-3 K miles;)
Today I went for a lunch ride. Did two 20 mile auto tune runs with the new tune suggested by Dynojet (they recommend three, 20 mile auto tune runs). Ambient temp was 98+ deg. so I forgot the third run. Felt like I was melting so I finished up at home and sat in the AC. When I walked in the house the thermometer on back porch said 106. Will do third run when I get a chance and then make a long ride and see what ET and Oil temps top out at.
May have to order some Liquid Moly Oil!
Sunman
I was at a dealer saturday they had 30 of them on the shelf, I bought two put one on last night , put 365miles on today , it seems to run cooler on p v , oil pressure is about 8 pounds higher . I had one of them that you take apart and clean I just dont think they filter out enough of the crap ?
Update on ET and Oil Temps
Since I first posted this thread I have now added an aux oil cooler and completed auto tune runs on the new tune received from DynoJet. Did an 85 mile lunch run yesterday, ambient temps were some where in the upper nineties on the way home (a 30 miles run to the house). ET hit 257 oil temp maxed out at 230 which is about a 10 - 15 degree improvement after adding the aux oil cooler. These temps are still high compared to what I have seen most other people post on the forum although some have wet heads instead of straight air cooled motors so I assume that might account for some of their lower temps. This is what I have done:
- DK Customs deluxe tank lift kit
- Mighty Mite fans
- Cobra slip-on mufflers
- DK Customs Hi-flo air cleaner
- De-catted head pipe
- DK Customs external breather kit
- Power Vision tuner with new DynoJet stage 1 tune and multiple auto tune runs
- DK Customs air deflectors
I am done throwing time and money at it. It is what it is. None of my previous Harleys ever ran this hot (2005 and earlier). I still have my old 1979 Shovelhead and the oil temp on it never goes over 185 deg. I am going to ride it and if it blows up I will just buy a Can Am.
Rant over. :mad:
Sunman
- Mighty Mite fans
Rant over. :mad:
Sunman
AMEN Same hear :D:D:D:D:D:D:D:D:D
  • Like
Reactions: MDO
new temps Danny. 295 mile ride today , mostly 2 lane & several towns,stop & go. Trike now has 7755 miles. temp was 91* oil filter 211 frt cyl 225 rear 250. No addons to Trike. Just K&N filter & Liqui Moly 10w 60. Oil changed last week. LM again. I will stay with this oil. Talked to K&N & as of right now they do not have a filter comparable to the new M8 filter from HD.
Thanks Bill. I ordered Liqui Moly couple of days ago. Due for an oil change so going to give it a try.
Sunman
- Mighty Mite fans
Rant over. :mad:
Sunman
Those are good temps. The oil is close to as good as you are going to get, and definitely in the safe range.
The ET is at the high end of where you want to be, but still good...not causing any accelerated wear.
I would not worry about the engine at all at those ambient temps and engine and oil temps.
If YOU are feeling too hot, there are things you can do to feel less heat...floorboard extension, cool vest, etc.
btw, I was doing some heat test runs the other day...ambient temp varied between 92-95 degrees. I was riding my Tri Glide and Dwayne was riding his M8 Softail.
(we were focused on his Softail, and the Tri Glide was just a "control" bike)
My oil and ET temps were very similar to yours.
For my personal comfort I was wearing my boots, kevlar jeans, gloves, helmet, and a mesh jacket over a tee.
Before each run I poured some water on my mesh jacket and was quite comfortable because of that. Would have been uncomfortably hot if the mesh jacket had been dry.
Thanks Kevin. I do have the floorboard extenders, one of the first mods I did after buying the trike. I always wear a long sleeve shirt, jeans, boots and gloves (and helmet). Need to get a cool vest with these temps, maybe a cool suit! :laugh:
Rode yesterday and the ambient temp was 98 on the way home. Oil temp was 230 and ET was 257 so the temps seem to be maxed out there.
Appreciate your comments; makes me feel better about the temps.
Sunman
Sunman
Sounds like you have your Twin Cam dialed in for warm weather riding! :)
Yeah, around 96 & higher seems to be the temp, where no matter how fast you go, the wind does not cool you down.
I really like the mesh jacket because you can get them wet and then they act like a swamp cooler...the evaporation is cooling. Mary prefers a cool vest.
I know when we were doing the heat testing runs the other day I was cool, did not break a sweat at the 92-95 with my mesh jacket (wet). Dwayne was just wearing a t-shirt. He was uncomfortably warm.
Sorry to keep this thread wandering off-track... Kevin.. which mesh jacket brand are you wearing? thanks.
