OK Now i've done it 2005 GW
Apr 14, 2011
60
12
Great Bend, KS USA
I wanted to set the windscreen down just a little more. so I read owners manual it says.
[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]To lower: Move the windscreen up to the upper mark ( ), lower it all the way (to reset the ratchet mechanism), then raise it to the desired position.
OKAY raised to upper mark and it wont go down very solid feel.
What have I done and how to et it to go down.
Jack
[/FONT]
If you released the locks on both sides, you should be able to lift up quickly and then you should be able to drop down to a lower position. Try rocking from side to side and forward and back ....... easy though !!!
If the above suggestions don't work, you may have ratchets that are fowled and stuck. You may have to remove some of the front mask area to get to them. It's not hard to do. The instructions for removing the windscreen is readily available on line. You shouldn't have to completely remove the shield, just expose the ratchets, lube and play with them a little. Most importantly, stuff rags in the dark holes around the mirrors or say goodbye to dropped fasteners forever. Good luck...... Jim
Thank you thank you
I done like you suggested then pushed down . Worked and I'm happy.
been messing with it all day.
thanks again
jack
Hey Jack, I bought my 2005 Goldwing Motor Trike from a dealer/installer in Great Bend, Kansas, in 2006. Can't recall the name. Was wondering if he's still in business?
