Tank lift kit
molokaimike
150+ Posts
Gold Member
Mar 28, 2020
183
250
Surprise, AZ
Mike
I will be adding a set of Love Jugs to my 2020 TG and I will be using the tank mount for them. While I have the tank off I thought that I would also add the tank lift kit when I reinstall the tank. I know that I don't have to remove the tank to add the kit but I thought that while I'm doing the one addition I might as well do the other. Any thoughts on what the best height lift kit should be used or is it just a matter of personal taste. Also, is it a good idea to add the optional kit that moves the tank back a little. I'm still a firm believer that buying the TG was the cheap part. Now all of the upgrades need to be purchased. :D
From what I have seen on here that people that did it, most went with the 1.5 inch lift with the deluxe option, some have did the 2 inch, I know Fearless did and his trike is a 2009.
All for now Trampas
I did the 2" deluxe lift on our trike and it really seems to help with getting more air on the motor, which means a little cooler and less buffeting in the face and chest. If you do a tank lift I would strongly suggest installing the Air Deflectors Kevin has developed which have been a God send to the trike it has really reduced heat. I also removed the mid frame air deflector to give the heat somewhere to go. I tried this after Kevin mentioned it once in passing my bride says she has no increased heat on her left side leg and foot. Stay safe Fred
On the Tri Glide you do not need the Deluxe Option in order to move the tank back. BUT, the Deluxe option does give a few benefits:
It lets more air flow over the engine for cooling
It exposes more of your chrome
It makes it easier to clean
It slightly changes the angle of the tank, sometimes allowing a taller tank lift to be used while maintaining clearance
Most folks do go with a 1.5", but you can easily check your clearance, following the instructions at this LINK, to see if you have clearance for a 2" lift.
btw, some folks also use the 1" lift. While taste does enter in on deciding the height, so does clearance, and perhaps the biggest is how much do you want to cool the engine and reduce rider buffeting.
I personally use a 1.5" with the Deluxe option, because of my custom bars, a 2" is a bit too high for good clearance. Otherwise I would use the 2" for best cooling, and reduction of buffeting.
As Fred mentioned, consider the CDW's at the same time. They are very effective.
Below is a new video we just did on Tank Lift Kit that you may find useful.
Ok, just ordered 2” tank lift with deluxe option and cooling deflector wings for my birthday present to myself, which is tomorrow, can’t wait to get. Next on the list is the 606 air cleaner and external breather kit.
Congratulations you will be very happy with the upgrade. Do yourself a favor do the upgrade with the low fuel light on much easier to handle the fuel tank. I did it the other way. Stay safe Stay Home and Stay Healthy Fred
Just installed the dk customs tank lift with deluxe option and cdw’s , very easy install, now I need to clean those dirty covers now that I can see them, will also have to play with the angle of the cdw’s more great products from DK, thanks Kevin
Thank you, we appreciate your business, and I believe you are going to like the benefits while riding.
Feel free to email us some pics of your ride to put on our website.
Kevin mine had about 1/2 a tank of gas in it and I didn’t have any problems at all, took about 30 or 40 minutes to get the lift and wings installed, very easy upgrade, hopefully tomorrow I can try them out during a ride.
Awesome!
I did the floorboard extensions yesterday. Maybe try the tank lift today. If I remember correctly I think the tank is pretty full and it's raining so can't go out and to burn through some.
Quick question for those who have the 1.5 inch lift. Is there enough room to aim the deflectors more towards the rear cylinder? Thanks.
I'm running the 1.5" on mine and I think I have my Cooling Deflector Wings in the sweet spot. They catch a good amount of air that does two things-
1. Stops it from going over the top of the tank
2. Redirects it over the cylinders and heads.
They mount on the bottom of the tank lift, so the height of the tank lift is not very relevant...unless you wanted them to be more horizontal...but putting them more horizontal than pictured in the video below at the 4:50 mark, will not catch as much air, and possibly have the tips running into the lower fairing.
The front cylinder is always going to get more air, but having them catch as much air as possible will push more past the front and over the rear.
Check out the 4:50 mark in the video to see what they look like with the 1.5".
Hope that helps.
I don't know if they were redesigned after this video was made but mine sweep up on the end.
Sounds like you ordered the Cooling Deflector Wings for No Tank Lift. They are a different design than the ones made to work with a Tank Lift.
These are for use with a Tank Lift-
These are for use with No Tank Lift-
In the video it looks like the deflector has the ear with the mounting hole bent in one direction and the tip of the deflector is bent in the opposite direction. In the photo of the two models of deflector the mounting ear and the tip are both bent in the same direction. Or am I not seeing the video correctly.
The CDW in the video is the same as the top one pictured above, made for use with a Tank Lift. No changes made.
The piece with the hole for mounting is pointed down, as is the tip of the wing. (well, down and forward)
Just went and found one of the Patent Drawings.
Here's another one-
Thanks Kevin, I guess what threw me was in the video I could see the mounting bolt for the tank so I thought that the wing was mounted with the mounting tab pointing up not down.
Thanks for post I didnt know you could do this . Guess I have parts to order and work to do:D:D:clapping::clapping::clapping::clapping::clapping::clapping::clapping::clapping:
