Has anyone out there used E-track and a tire tie-down system like Erickson's tire tie-down system? This system is shown in advertising as securing a hotrod. Any experience, good or bad? Seems like it might answer the question of crosstie or not.
Just thinking out loud here...just from looking at the picks it would seem to me that getting the straps threaded under the fenders and over the tire properly might be a challenge.
What if... a strap came loose... what fender damage might happen? Also, there is no side-to-side movement security as you normally have on cross-tieing the rear down.
I agree with PosseRider... the condor chock for the front wheel and then I cross-tie the rear-end to the D-rings on the trailer via the trailer hitch bar underneath the trike. Additionally, I wrap a tie-down around the front wheel after it is in the chock and secure its ends to the front D-rings - just for peace of mind.
I've used the transport mode, and I've also tried leaving the key fob in the tour pack(enclosed trailer). Both work for me, never had the battery go dead while towing it.
https://www.condor-lift.com/shop/category/condor-for-trailering Used this one for years. Holds bike upright once you ride into it .Then get off & secure to D-rings in floor
Question about the rear tie down procedure suggested using the 'loops' on the TG frame and crossing the straps to the opposite side of the trailer. The mufflers hang down below the loops so once the crossed straps are tightened there is tension on the mufflers. Not sure if this is a problem but it is a concern. Anyone ever had a problem doing this?
I have towed two different TGs on/in two different trailers all over the country. We will leave Florida this spring pulling yet another different style (tandem tow). I have never crossed the ratchet tie downs on the rear frame loops. I have always set mine up to they pull down and slightly back. Been on some pretty rough and bouncy roads and have never had the bike move.
I never wanted my ratchet straps to touch mufflers or anything else under there.
I have the E-trac tiedowns that I just put on my new TK1 Trailer plus I tie down from the front and cross tiedown the rear. I had the E-trac tiedowns in my enclosed trailer and hauled my trike to the Maggie Valley rally last Sept. and I did not move at all. It is very easy to slide the straps over top of the tires and strap them down. If the straps come off the tires, you did not have them tight enough. That tiedown system is the same system that they use to tiedown new cars when they transport them to dealers.
Tow your trike down to Texas so we can meet you and your wife.
