Indian Chieftain - Is it the battery, or other electrical?
Jan 11, 2020
1
1
Red Lion
I had gotten sick and hospitalized with some surgery. I was not allowed to ride for 6-8 weeks and realized I never plugged in my trickle charge. When I discovered this and plugged in everything seems dead. I can't even use my fob to unlock the trunk. Won't pick up any charging on the trickle charge either. Any help would be appreciated.
Welcome to Trike Talk
Always check the battery first. A fully charged battery should read at least 12.5-12.7 volts
After charging, let battery sit for 1 hour. Connect a volt meter on the battery. As you turn engine over the volts should not drop below 10.5. You can also do a voltage drop test by turning on the head lights then record the voltage. If the volts drop below 10.5 and continue to drop, the battery has seen better days
I have found that some chargers will not start a charge cycle if the battery it is connected to is completely discharged. You may have to hook a conventional non trickle charger to it set at 2 amps and let it slow charge.
Rodney ; Welcome to Trike Talk-,,,:wave4:.....Your battery is so low voltage wise that a trickle in most cases cant charge it....You will need a regular charger to get some voltage in the battery then your trickle charger will finish the charge....Don't leave the regular charger on too long......Just enough to get the trickle to working......
After checking the charged voltage you may find it low.. most likely a dead cell. New battery time.
