Harley trouble codes
Jack Klarich
Gold Member
Oct 11, 2016
18,131
15,217
Jacksonville, FL
Jack
Harley Trouble Codes
The following procedure will instruct in retrieving and clearing ECM Diagnostic Trouble Codes and TSM/TSSM codes through the Harley guage cluster as well as a list of codes.
1- Turn Ignition switchto OFF & Run/Stop switch is to Run.
2- Push odometer resetbutton in & hold.
3- Turnignition switchto Ignition and release the odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer resetbutton once and you will seethe selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer resetbutton one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM(Electronic Control Module)[EFI] /Ignition Control Module[Carbureted])
S = TSM/TSSM (Turn Signal/ Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer resetbutton in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer resetbutton again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer resetbutton. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signalmodule
DTC’s are designated by a P,C,B or U
P codes indicate issues monitored by ECM
C codes indicate an issue with ABS
B codes are set by Radio, Instruments and BCM
U codes indicate a communication problems with the modules
Fault Code Abbreviation List
ABS – Anti-Lock Braking System
ACR – Automatic Compression Release
AFR – Air Fuel Ratio
AIS – Active Intake Solenoid
ATS – Air Temperature Sensor
BAS – Bank Angle Sensor
BCM – Body Control Module
CAN – Controller Area Network
CCM – Cruise Control Module
CKP – Crank Position Sensor
DLC – Datalink Connector
DTC – Diagnostic Trouble Codes
ECM – Electronic Control Module
ECT – Engine Coolant Temperature
ECU – Electronic Control Unit
EFI – Electronic Fuel Injection
EFP – Electronic Fuel Pump
ET – Engine Temperature sensor
FI – Fuel Injectors
FPR – Fuel Pressure regulator
H-DSSS – Harley-Davidson Smart Security System
HCU – Hydraulic Control Unit, ABS
[/stag_one_half][stag_one_half_last] HFSM – Hands Free Security Module
HO2S – Heated Oxygen Sensor
IAC – Idle Air Control actuator
IAT – Intake Air Temperature sensor
ICM – Ignition Control Module
IMAP – MAP + IAT in one unit
ISS – Ion Sensing System
JSS – Jiffy Stand Sensor
LHCM – Left Hand Control Module
MAP – Manifold Absolute Pressure Sensor
MHR – Right Hand Control Module
RCM – Reverse Control Module
TCA – Throttle Control Actuator
TGS – Twist Grip Sensor
TMAP – Intake Air Temperature / Manifold Absolute Pressure equipment
TPS – Throttle Position Sensor
TSM / TSSM – (Turn Signal / Turn Signal Security Module)
VE – Volume Efficiency
VIN – Vehicle identification number
VSS – Vehicle Speed ​​Sensor
WSS – Wheel Speed ​​Sensor
P0031 Front HO2S low/open
P0032 Front HO2S shorted/high
P0051 Rear HO2S low/open
P0052 Rear HO2S shorted/high
P0072 AAT sensor low
P0073 AAT sensor high/open
P0107 MAP sensor failed low/open
P0107 Map Sensor Open/Low
P0108 MAP sensor failed high/open port
P0112 IAT Voltage Low
P0113 IAT Voltage Open/High
P0117 ET Sensor Low
P0118 ET Sensor High
P0120 TPS1 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0131 Front Oxygen Sensor Low / Engine Lean
P0132 Front Oxygen Sensor High / Engine Rich
P0134 Front Oxygen Sensor Inactive
P0151 Rear Oxygen Sensor Low / Engine Lean
P0152 Rear Oxygen Sensor High / Engine Rich
P0154 Rear Oxygen Sensor Inactive
P0220 TPS2 Range Error
P0222 TPS2 Low/Open
P0223 TPS2 High/Open
P0261 Front Injector Open/Low
P0262 Front Injector High
P0263 Rear Injector Open/Low
P0264 Rear Injector High
P0265 Rear injector shorted high
P0371 CKP sensor wrong number of pulses
P0373 CKP Sensor Intermittent
P0374 CKP Sensor Synch Error
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P0501 VSS Sensor Low
P0502 VSS Sensor High/Open
P0503 VSS failed high
P0505 Idle speed control unstable
P0562 Battery/ECM Voltage Low
P0563 Battery/ECM Voltage High
P0572 Brake Switch Low
P0577 Cruise Control Input High
P0603 ECM EEPROM Memory Error
P0605 ECM FLASH Memory Error
P0641 5 Volt Reference 1 Out of Range
P0651 5 Volt Reference 2 Out of Range
P0691 Fan/cooling relay output low/open
P0692 Fan/cooling relay output high
P1001 System Relay Coil Open/Low
P1002 System Relay Coil High/Shorted
P1003 System relay contacts open
P1004 System Relay Contacts Closed
P1009 VTD Disabled Fuel Due to Incorrect Password
P1010 Missing Password
P1017 ET indicates overheating
P1019 ECT Difference (high temp)
P1270 TGS 2 A/D Validation Error
P1351 Front Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1353 Front Cylnder No Combustion
P1354 Rear Ignition Coil Driver Open/Low
P1355 Rear Ignition Coil Driver High/Shorted
P1356 Rear Cylinder No Combustion
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High
P1510 EFI Limited Performance Mode
P1511 EFI Power Management Mode
P1512 EFI Forced Idle Mode
P1514 ETC Air Flow Fault/Error
P1600 EFI Module Processor Internal Error / Watchdog Error
P1608 Loss of continuous battery
P1655 ACR solenoid low/open
P1656 ACR solenoid shorted high
P1691 Cooling fan left low/open
P1692 Cooling fan left shorted high
P1693 Cooling fan right low/open
P1694 Cooling fan right shorted high
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2105 EFI Forced engine shutdown
P2107 EFI Module Processor Internal Fault
P2119 EFI Motor Throttle Body RangePerformance
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2135 TPS Correlation Error
P2138 TGS Correlation Error (Twist grip sensor)
P2176 EFI Closed Position Not Learned
P2184 ECT sensor low
P2185 ECT sensor high
P2300 Ignition coil driver low/open (front)
P2301 Ignition coil driver shorted high (front)
P2303 Ignition coil driver low/open (rear)
P2304 Ignition coil driver shorted high (rear)
Need help with diagnostics
This may not be the place to ask, but I need help. This issue is not about my Freewheeler rather a good friends bike. (2008 Street Glide) In the past year, his check engine light has come on a couple of times with no other issues. Then recently, soon after a grip change it went into limp mode. We looked at the infamous green connector (for the TGS) in the handlebars and it looks fine, that is, not broken or disconnected. Now it's running fine again. Here's the problem. When we try to check for codes, we get P = no response, S = none, SP = none, T = none and b = no response. I believe the "b" is for anti-lock brakes which he doesn't have. Why do we get "P" = no response? The handlebar switch is "on". This bike has a Power Commander if that matters. Thanks for any ideas.
Strange with no response
The B is strange, I thought B is BCM?
Is The Power Commander capable of codes like the PV Tuner?
Thanks Jack, but this b seems to be an area of the diagnostics, not a DTC. The menu comes up as PSSPtb . The first area P and the last area b show "no response". The other three show "none". I'm really not familiar with the Power Commander either, but I don't think it's that advanced. Maybe it could be keeping the P from giving us the diagnostic view of the ECM? :xzqxz:
If the PC is plug and play I would un hook it and try a scan
DTC b2121 BCM malfuncti0on
I had a steady red check engine light on my '16 TG that popped up out of the blue. No maintenance lately or anything other than riding and wiping down. I followed Jack Klarich's advice to run through the DTC's and clear out the code, which turned out the light. 300 miles later still no problems. Thank you for your help, sir.
edumou
