I changed out my stock bars on my new 2019 TG and now I have a check engine light on. I rechecked all the wires I unplugged and plugged them all back in again. Everything works fine except for the light on the dash. Any suggestions??.
No DTC codes logged is what it says.
That's what it says, I even tried to up a picture, but that's not working. I'm lost.
I took it for a short ride up and down my street and as far as I can tell it works just like it did before. All switches work, lights, radio, and other things seem in order except for the check engine light. I've checked the DTC codes several times and no codes noted. ??
Thanks for the ideas anyway. Looks like a trip to the shop for me. I don't even have 250 miles on it yet.
How do I do that? Not sure which is the neutral light switch. The brake lights did work, haven't checked the cruise control.
I started the bike, it showed the neutral light on. Pulled the black wire with it running and the neutral went out. Shut off the bike and open up the DTC and it shows no codes. Tried to start the bike without using clutch and brakes and no start. Put the wire back on, the light lit and was able to start the bike. Pulled both wires with it running and shut it off and looked at the DTC again and no code.
I also went back out earlier and the cruise control works great.
So it appears that it's not registering codes on the DTC.
Did you pull the main fuse prior to changing the handle bars? Might want to turn the bike on and put it in the accessory position, then pull the main fuse and then turn the switch to off. Wait 10 min, then plug the main fuse back in and see if the engine light come back on. If it does it is time for a trip to the dealer I expect as it is under warranty.
I did as above and it didn't make a difference. Started the bike and still had the service engine light. Let it run a bit then shut it off. Tried the DTC again and it finally has a code of U000100. Reset the code and started the engine and still have the check engine light.
I took the bike to the shop today and there was 10 codes in the computer and all were historic. They simply reset the system with the computer and all is well. The tech said that I had started it with something disconnected and that was the reason for the check engine light and needed the computer to reset it. I did start the bike with the headlight disconnected, so it was something that I did. I'll know not to do that again.
The tech got the codes through the trip meter instead of the boom box. So, I didn't ask him why the difference.
I dunno if the scan works the same on your Triglide as mine, try holding down trigger switch on LS switch pak then turn ignition to on position. Your speedo gauge should sweep then go to scan for DTC
Look here
This is how the tech got the 10 different historical codes. He reset everything and it's working great now.
