cooling fans never seem to come on
Feb 7, 2018
17
13
Sparta Mi usa
I have a 2015 trike mostly stock and when I bought it new the cooling fans seemed to run most of the time when I shut it off but recently the fans never seem to come on. We were riding in 90 degree weather and normally the fans would kick in but not now. I have tried them manualy and they do work what else could it be.
I would think that, like most cooling fans, they are thermostatically controlled. I would, after checking the fuse as Fuzzy suggests, jumper out the thermostat & see if they run & if they do, remove/replace the thermostat.:cool:
Try this to see if both fans come on
Turn your bike on, don't start it, then roll the throttle half way and the pump and fans will come on. This feature lets you check everything works and helps get the air out if you ever have to drain and refill the system. Pump and fans run until you turn the ignition back off.
That's amazing. I just went out in the garage and gave this a try. Sure enough the fans came on. Thanks for sharing.
I have done this and both the pump and fans come on, another trike owner said it could be the pump going out as he has replaced 3 on his 2016
Has your coolant light or engine light come on and stayed on?
Have you checked for stored codes?
Harley claims few issues with their thermostats, saying more often the pump goes bad
Jack, doesn't the thermostat control the fan coming on? Please correct me if I'm wrong.:)
I am not sure how it works with the engine coolant temp sensor, I have not had the displeasure of working on one of these systems
I would think if one was having problems with one of these there should be a trouble code and or an engine light on
Pump, if the pump has not been changed out it is probably the pump. Put your hand on the pump and do the throttle trick to see if it starts. Mine would run sometimes and other times it would not. The Magnetic coupling was
Cracked and sticking or binding.
redhog99
