Help with brake wiring
Aug 24, 2009
17
4
PA
Victor
Please help
2008 stallion need the wire chart For right side brakes light
Had a bad switch so I removed it and try to connect them straight to the lights but got the wires mixed up and now I’m confuse
Victor I'm confused with what you need. The right side and the left side are the same brake light. Can you post a picture of the problem area and I will get you an answer. Or a better description of what you did and where.
Thank for your help
i was able to fix the problem
But of you have part # for brake bulb socket will be great
