Rear Brake Flush/Bleed on CSC Trike
rhino65
250+ Posts
Aug 14, 2016
263
49
Atwood, IL
Brian
Needing to flush rear brakes on my Cobra CSC Trike. What's the sequence to this? I believe the rears are linked to fronts. Correct me if I'm wrong.
Try This
Cobra trikeBrake bleeding procedure:1.Using a vacuum bleeder, follow this procedure carefully.a.Left front upper bleed valve.b.Right front lower bleed valve.c.Rear caliper rear bleed valves.d.Anti-dive bleed valve.e.Rear caliper front bleed valves.2.Hand bleed the system using the above sequence. Until all air is removed from the lines.3.Allow the bike to set for a minimum of 20 minutes and recheck.4.If there is excessive pedal travel on the first pump, repeat steps 1 through 3
  • Like
Reactions: MDO
Did it work for you my goldwing has setting for long time i have no back brakes
What is the condition of your master cylinders?
If there is fluid left in them you may want to suck out as much as you can and clean with a cotton swab any residue in the bottom of the cylinder first
This way no crude will enter the lines
  • Like
Reactions: MDO
Bullet Proof
