Belly pan
I know nothing about a Viper BUT you can be sure the first thing that I installed on my 2010 Honda Goldwing was the belly pan, on my first Goldwing (2002) I was lucky enough to have just installed the pan, when I took a road trip, I then ran over some kind of piece of metal, laying road, I missed seeing it cause I was riding behind a 18 wheeler and didn't see it.. BANG! I heard a loud sound, looked down, and saw this piece of metal, fall off the bike.. I stopped and looked under the bike, "everything" was fine ,BUT I had a huge dent on my pan, right where the oil filter would have been, if this pan wasn't installed.... (would it have punctured my oil filter?? / That I will never know ) BUT that day on I have always installed the belly pan.. MY .02 worth of knowledge...;);)
Ronnie
Belly Pan
Well, after reading the input from several of our members about the pros and cons of having a Belly Pan, I ordered a Progressive Black vented Belly Pan from Wingstuff this afternoon. I should have ordered one years ago but just never did so. I will be mounting it onto my 2007 Gl1800 Champion Trike. My wife reminded me that when we travel it seems that rocks and debris just seem to be waiting for us to come along. :( I believe this will be money well spent. Thanks for all the input to this thread. Great Forum!!:clapping::clapping:
A belly pan also protects the plastic coolant reserve tank that is located at the rear and below the engine case on GL1800s They are notorious for getting punctured. I had one punctured years ago when loading a trike on a trailer. The trailer had an expanded metal wire mesh floor and the pointy end of a piece of that caught the tank and ripped it. I have spotted aluminum sealant tape repairs, JB Weld repairs and silicone glue repairs on coolant tanks quite a few times on GL1800s in my shop for conversions. If your trike has running boards, a belly pan may not fit in some cases.
A belly pan also protects the plastic coolant reserve tank that is located at the rear and below the engine case on GL1800s They are notorious for getting punctured. I had one punctured years ago when loading a trike on a trailer. The trailer had an expanded metal wire mesh floor and the end of a piece of that caught the reservoir and ripped it. I have spotted aluminum sealant tape repairs, JB Weld repairs and silicone glue repairs on coolant tanks on quite a few Goldwings in my shop for conversions. If your trike has running boards, a belly pan may not fit in some cases.
+1 When I got my trike it had a hole in the coolant tank, put on a belly pan and it has saved the underside parts many times. I have taken it off and straightened it 3 times in 2 years.
Papa Zook, the very first time I got my trike up high enough I could really get a good look under it that reservoir tank, oil filter stood out at me like an accident waiting to happen.
I have running boards on my trike so maybe I need to do some homework before ordering.
If anyone is running a CSC viper with belly pan please chime in. Thanks
Dennis, you might give Dwight a call at CSC and see what he says.
[FONT=&quot](800) 824-1523[/FONT]
Don't know about fitment for a CSC Viper, if you can use a belly pan think about getting one that is 2 piece, you can remove the front part to make changing the oil filter much easier. The 1 piece has to be completely removed to get to the filter. Install is a little challenge, you need about 4 hands.
What brand belly pans is everyone running? I agree on the two piece pan being the better option.
I got mine from WingStuff, packaged by Show Chrome, WingStuff item # BB52817.
Aircraft grade aluminum (They Say), vented, 2 piece construction, has a hole for the coolant overflow hose.
Sorry Papa Zook, I forgot about this suggestion. I’ll see if I can get that done today and report back.
I sent an email to CSC. I got a response back that said they will definitely fit but will be a hard install as the ground effects is in the way to access the exhaust bolts needed.
Again i I guess I need to crawl under my trike and take a look. If it’s a matter of removing the running boards (ground effects) to install I’ll probably go with it. However if the running boards interfere with removing the front half of the belly pan for an oil change I’d have to think twice.
I hear you Dennis. If you find out that the running boards interfere with the front half coming off and decide not to install it, I have a suggestion for an easy and free fix on protecting the coolent tank that works great. I can post some pictures later from my computer, don't have the pics on my phone.
May be late to the party, but a few tips on belly pans -
The 2 piece pan advantage has been mentioned, but I found it easier to remove/replace the front piece if they use dzus fasteners. I had one on our old 1500 trike that had a captured nut on the larger part and, other than losing a bolt now and then it was harder to get the thing lined up to put it back together it the plate was a bit bent or dented. And they will get bent or dented. They can be thought of as a sacrificial part.
There are 2 designs of the holes/slots that connect the pan to the frame. They all use the exhaust cover bolts, but some have horizontal slots along the edge like this
An advantage is with elongated holes it can be adjusted front and rear a bit if needed, and it isn't going anywhere after its installed as the bolts have to be completely removed to install or remove the pan.
The other design has perpendicular slots:
belly plate 1.jpgThe exhaust cover bolts just have to be loosened to install this version, and it will be a lot easier to install, especially if you have running boards as the bolts don't have to come out.
The first kind pictured (ours is without louvers) came on our 1800 Champion trike from the PO, and I do sometimes wish I had the second kind with perpendicular slots when it comes time to drop the pan and pound out a dent.
Our '97 has survived so far sans a belly pan, but once a piece of shale lying in roadway in a dark shadow (I was leading group, bright exceptionally clear day, harsh shadows) was clipped by the front tire enough to cut the tire (not through cord, but raised a bruise on tire on left side) and stand the shale up edgewise (I guess) and it got caught by the lower front cowl, it wrecked lower cowl and wrinkled the left side lower exhaust cover, missed the shifter though … could have been worse.
Those 3/16 rivets are where I had added reinforcement years earlier to back side of cowl at mount points as there was a crack in that area on other side. I have a nice piece of 1/4" aluminum, saving it to make a belly pan one day. As it was, was able to finish ride and found replacement parts that night from a salvage yard in Fla. Paint even matched. A pan maybe wouldn't prevent this, but it might prevent a hole under transmission.
Best plan … don't hit stuff.
Friend was loading his trike on trailer and caught trailer frame with his trike's transmission & cracked it …. oil leaked … his insurance co paid for repairs (replaced his engine & trans from salvage I think).
Well, I put my Wingstuff black powdercoated belly pan on my 2007 Gl1800 Champion Trike today. Piece of Cake! It took maybe 30 minutes and I am a total clutz when it comes to mechanic work. So if you are wondering how hard it is to put on......EASY, so easy even An Old Man can do it. :D:D:clapping:
There is no problem removing the front portion to change the oil and filter or the coolant. The CSC ground effects come off very easily. There are 6 nuts on the bottom of the boards and 1 electrical connector. Removal hint.. remove the 2 center nuts on both sides and swing down the support bar for easier removal.
I have the belly pan on my Roadsmith w/o any problems, and changing oil/filter is easy..I just have to jack up my bike first and place four inches of boards under all three tires.. This makes it high enough off the ground to work underneath...........
Ronnie
Trustme54
