Signal Dynamics brake light interupter
Nov 22, 2016
245
131
Groesbeck, TX
James
2016 triglide: Can this brake flasher be installed on my trike? I assume the fender lights are 1157 but don't know what the brake lights on the tour pack are. Thanks in advance
I am not familiar with this particular flasher so I cannot answer your question. However, I do recommend you consider products from Custom Dynamics which I have used for many years. As far as I know Custom Dynamics is pretty much the undisputed leader in lighting products for our Harleys.
I asked about what products to run in my 2018 Tri-Glide and here is what Custom Dynamics suggested:
Use the MAGIC-STROBES-TKE to apply patterns to the left and right taillight (requires taillight be converted to LED) and the MAGIC-STROBES-LTP2 to strobe the tourpak. Both products can be viewed at the links below:
MAGIC-STROBES-TKE
https://www.customdynamics.com/magic-strobes-brake-light-flasher-for-harley-davidson-triglide?cat=61
MAGIC-STROBES-LTP2:
https://www.customdynamics.com/magic-strobes-ltp2?cat=61
I did not convert my taillights to LED so did not purchase the 'TKE'. But I did buy the 'LTP2' to add flashing pattern(s) to the center tour-pak light which is LED . . . and I think your 2016 is LED also but may want to verify that. My thinking was that the tour-pak lights are more at eye level and the flashing pattern would be plenty noticeable. And I didn't want to spend the $300 ($150 each) for two new LED taillights. I did install some LED bulbs only in the taillights but pulled them out as they were not nearly as bright as the stock incandescent bulbs. Go figure!
Anyway hope this helps and good luck. Maybe someone else can answer your question about the Signal Dynamics product.
