Left Rear turn signal problem???
Jun 13, 2015
10
Copperas Cove
My 13 TG is equipped with the HD security system. When I turn on the ignition W/O the key fob. both front and rear turn signals flash like their suppose to. When I turn the ignition off, both the front turn signals flash several times along with the right rear turn signal. The left rear turn signal does not flash. My rear turn signals operate normally when riding. including 4-way flashers and brakes. Also when I attempt to "move" my TG w/o the key fob and engine off, my turn signals will flash except for the left rear signal. The security system appears to be working correctly. My rear turn signals/brake lights are HD LEDs. Do I have some sort of lighting problem? Any info or help is appreciated.
Pre 2014s "usually" need a resistor to work properly with LEDs. Some LEDs may be marginally close to the resistance required to work properly without the additional resistor. If all your lights work normally .... and only malfunction on the cycle security indication flashes .... I wouldn't worry about it.
Bob :D
Check the connections
I had the body off my '13 week before last. Had to disconnect all the rear lighting, etc. to get it off. When I got it all back together, I had the same problem as you are experiencing. Went back through all the wiring and found a connection that had not gotten connected fully. Pressed it together and all works fine now. I have LED lights all over the rear end of mine, but not as many as others!
dhinzman1
