Pig trike
May 7, 2016
47
31
Westbrook, MN
Robert
:presents: I found this setting in a side yard in the country. After some haggling, we settled on $200.00.
We put it in my daughter's pickup bed, and went home. My daughter told me that since it was my trike, and it was hiding her tail lights, I had to drive the 50 plus miles home. I made it.
I got two cardboard boxes of parts, a plastic bucket of rusted nuts and bolts and a late style "rebuilt" engine.
If someone has spare engine parts they want to sell, please let me know. It is a 1600 dual port engine. No engine tin at all, no part of an intake manifold, no fan housing, no alternator, and no fan. I do have a new (10 plus years old still in the package) oil pump with an attached filter, and a distributor drive gear. No carburetor, no rear pulley, not much of anything really. I'm not begging for handouts, I'm want to pay for what I get. Purple Pig 11.jpgPurple Pig 1.jpgPurple Pig 2.jpgPurple Pig 3.jpgPurple Pig 4.jpgPurple Pig 3.jpgPurple Pig 6.jpg
This poor old pig trike has been setting in a side yard for six years, and unknown years in other places, but I will get it going again.
Thank you.:titanic:
Nice find! Is this your first VW trike? If you've worked on type1 VWs before you probably have most of the basic tools to break the engine down and check it's "rebuiltness". Might get lucky and have some usable parts inside. Biggest worry about old engines stored outside is that if they were sitting on the ground, you might have porosity issues with the magnesium cases.
Check out the Souix Falls VW Club on FB. They can probably hook you up with some local resources.
I'd like to see a pic of the frame when you get the body off.
Thank you.
I enjoy a challenge. I like working on stuff, except in the garage in S.W. Minnesota with a temperature of 20 degrees F.:gaa:
Thanks for the info. This will be my third trike build, but my first Swing Axel of any kind.
The engine was setting in a fifth wheel travel trailer. I am just guessing, but I think the previous owner pulled it, put it in the trailer, and sold off parts. I have a lot of VW tools, but most of them are in my 1971 Bajie bug setting storage in the middle of California. I have enough to get by with.
I just checked out Souix Falls VW Club on Facebook. Didn't come up with much, but other VW Facebook sites came up. Thank you, I never thought of looking on Facebook, just the parts houses; Appletree, Aircooled.Net, etcetra.
Will start buying parts after the third when I get my monthly Social security check.
There are a lot more pictures of the trike from before I started taking it apart. I will get on the pictures now that it is inside, and in a bunch of pieces.
Thanks for the information.
Robert.
Before I did anything I'd title it in my name. Unless your state doesn't require a title. Nothin like spendin time and money on something you'll never be able to use.
Perfectly valid point. I'll add that to my to do list.
Thank you for thinking for an old man. (71.5 years old, but feel 35.):senile:
Robert
Robert
Nice that your health allows you to keep going like ya do. At least your quest is on the positive side to pass the winter time away. All ya need is some garage heat ! Good luck Robert :clapping:.
Lots of different things can happen to things from sitting out side in the weather and abuse.
Nice find, glad to year that you are younger in spirit than physical age. Think young and the mind stays young, just our bodies go to crap on us.
A lot of tips, but I like the one " go to DMV first thing, get legal papers on it" and do not let them talk you into a non op on it until road worthy,, this can cost you money and time also.
Best to get it legal and pay reg. fees each year. Even if it just sets in the garage, I say it is the price to pay for ownership.
Taking off the body is good, as one should look over all welding joints and all so inspect the frame for damage or bent parts from previous accident. With frame bare one can roll it over a square drawn on the garage floor to see how all lines up.
Next the trike has hydl. front fork's , or inner tube springs ?
Both of these suspensions have a limit in their operation. From what I have read (rebuilding my front end) is that they start to fall short on working properly once you get to or past 45 degrees in rake angle. I also read on article that said 42.5 degree's is when they start to diminish in compression ratings.
Just sit down with paper and pin and write it all down that needs to be done or service checked. Than just go down the list repairing and checking things off as you get them done.
It was nice of you to save this ride, maybe you can bring life back into her.:)
The rear wheels appear to be Cragar SS wheels, I have a set just like them for my 69 Plymouth GTX.
Thanks frank.
I'm not as spry as I once was, and I can't hold a Chevy 350 small block out in front of me like I used to, and instead of urinating on the ceiling the first thing in the morning, I now fill up my slippers, I'm still in good shape (what's left of me, that is.):blush:
I was considering propane, but you get a twenty pound tank filled to only fifteen pounds from the Blue Rhino propane company. They charge you for twenty, but give you fifteen, if I read their advertisement correctly. The second option is to drive one hundred miles to Souix Falls, South Dakota, and one hundred back. I can't see the mileage, but I doubly can't see getting bent over the tank (pun intended).
My daughter has said "no electrical heaters in the garage, it does crazy things to my electric bill."
I guess I'll go to the grocery store where they sell Blue Rhino, and walk in with my pants down around my ankles, metaphorically speaking.:kpzxvq:
Be safe;
Robert
Life is short, and the older you get, the shorter life gets. Always try to have fun and have it the way you want it.
Be safe;
Robert.
Yes, the wheels are 14" Cragars, with a tread width of 10". They're no longer holding air, but I don't see any cracking in the sidewall. They are L60-14, and I cannot find an equivalent modern tire size. When I was in my mid twenties, I had M50s on the front of my '69 Charger, and M60s on the rear. (440 Mag engine, 4 speed, Dana positract, 1/2" cam, headers, high rise with a 750 Holly double pump. I could get the front end about three feet in the air when the M60s were new, after they wore in, the beastie would try to wipe out the vehicles beside of me. I had to be doing at least 25 mph before I punched it. When I first got the car in a trade, I tried to top end it. The speedometer hand got stuck on the wrong side of the peg BEFORE 0.
Thanks for the trip down memory lane, which is only a quarter mile long.
Robert.
I'm still making out lists to figure what to do first.
1. Replace the front end because there is no hydraulic action in the front end on the trike. I added oil to the cylinders, and all I got was an oily floor. I have a leading link front end I made for the unfinished trike I left in Lodi. The leading link has 1900 miles on it without turning a wheel from being in the back of the van on the trip to Minnesota. 2. Get a Kawasaki Ninja rotor and bolts for the front brake.
3. Find out what the front caliper on the trike is and rebuild or replace it.
4. Hand and throttle grips.
5. Front brake master cylinder and lever
6. A new set of swing axle rear brake lines.
That should take all of my social security check, so I'll pull some things off the list till next month so I have enough money left to buy the dog her food. I'm changing her name from Sharlee to Bar-b-Que. :evilgrin:.
Be safe, y'all.
***Yes ,grandpanystrom61, they can, and it seems like they're all bad.
***It's like George Burns said, "I'd date girls of my own age, but there are no girls my age" ;)
***I like this one best also. In Minnesota, they do not have non-ops. They don't even know what a non-op is. I tried to put one on a car I bought, and they couldn't understand. I junked a car in Lodi that is still on a non-op. They keep sending notices that I don't have to do anything, and the car will stay non-oped.
***I don't think they charge registration on a vehicle here if I just transfer it into my name without registering it. I could be wrong.
*** The body is off, and from the measurements from the outsides of the torsion bar tubes to the center rear of the neck it is within a 32nd of an inch, and that could be form the bolt being loose in the hole.
Next the trike has hydl. front fork's , or inner tube springs ? Both of these suspensions have a limit in their operation. From what I have read (rebuilding my front end) is that they start to fall short on working properly once you get to or past 45 degrees in rake angle. I also read an article that said 42.5 degree's is when they start to diminish in compression ratings.
***The trike has hydraulic forks. It looks kinda like a 350 Honda, but I'm sure it isn't. I'll post more pictures. I didn't do a rake angle yet, as my rake magnet is in my Bajie bug in Lodi. Ill get one this next week, weather permitting. I made a leading link with a set of 5' down tubes that I'm considering using if I can get some co-operation from the dmv here. I want to cut the neck that's on the trike off and use the neck I had made for the leading link. If I use the complete front end, there will be less hassles. If I get to change the neck, the front end will be at a ridiculous rake, but it will only have about two inches of trail, and it will ride like a Cady on the road, and a go cart in the curves, minus the slipping off the road.
***I have a ream of paper in the garage that I've been using for writing. I can't get my ink pen out of my hand because of the swelling from all of the lists.
***One way or the other, I'll finish it. My daughter is already calling it hers, because when I die, she becomes the beneficiary.
Thanks for the talk, be safe.
Robert.
Glad you made the save....a new project can shorten a long winter!
Larry, I'm glad I made the save too because doing this trike will keep me off the road, and out of trouble for a long time. Lets just hope that tomorrow I still remember what I thought of today for doing to the trike, or something like that.
Be safe;
Robert.
It may sound a bit off, but Harley seems to have nice aftermarket priced brake calipar and Master cylinder and lever prices. I got stock on a set size of front tire and this lead me to Triumph, and so I did their calipar and lever control. It worked out, but I did over pay for my choice. Now just hope it was worth it.
They are less expensive because they are a single piston design, my choice was a dual piston calipar.
Out side, wiring insulation could be cracking up means a new wire job is in order. Seems many get a dune buggy wiring get for their trike's. It seems to work out well.
Dash panel is missing up front, so for me I used a piece of aluminum for my dash face piece.
Easy to work with, a pain to paint, but it worked for me. Why do it, bug motors do need some instruments so the rider can keep an eye on the engine and how all is working, okay I felt better putting them in so I could keep an eye on it all. Again not a bad choice.
You will have fun I am sure. Yes propane is a pain on the bottle exchange, they take everyone with it, but it does deliver more heat than electric does. I know as I did/do the electric heat at times, costly compared to the propane buddy heater I have.
Be safe and enjoy the new ride.
Thanks frank.
Be safe;
Robert
I’ve got one of those Sunflower type heaters at my home garage, that mounts on the tank valve. It does take the chill out of a one car garage.
Is your garage detached? If so, this might be a good option: https://www.homedepot.com/p/US-Stov...VWbbACh16KgqjEAQYAiABEgKv__D_BwE&gclsrc=aw.ds
Just add a 55 gal drum and stove pipe.
Another option is to check the local propane service and see what's the smallest tank that they'll come out and fill. Check CL and find a good used 100 gal (or whatever) tank, some copper tubing, and a wall mount Catalytic heater and you're in business!
Check local codes and homeowners insurance requirements first. Many more options for detached vs. attached garage.
pig trike
The pig trike does have a 350 Honda front end on it. I hadn't seen one in 44 years. I am going to get a Honda Complete Brake Master Cylinder for $44.95, a Front Brake single Caliper (stock) Assembly for $99.95, and a 7" side mount Honda headlight for $39.95 (it should fit the first two holes in the body, with a little help from longer mounting bolts, washers, and pieces of pipe).
There is no wiring on the trike at all. I like it like that as I'm very good at wiring stuff up. I do not follow a plan, I just wire one system up at a time. I have a Tupperware bin plum full of wire.
On the missing dash, I have a flat sheet of 1/8" aluminum that I'll cut to bolt behind the dash hole with small nuts, bolts and, washers. Buy some plastic caps at the truck stop to silicone over the bolts. You're right about aluminum being a pain to paint, but I learned a loooooong time ago in the army; if it moves, salute it, if it shines, paint it. The trike paint scheme is to be John Deere Green, Fire Engine Red, and Olive Drab Green, preferably done in pickup bed liner so there is no polishing.
Yes as soon as I get the check, Ill sign up for the propane.
Be safe.
Robert.
Frank; That's what I'll end up doing for warmth in the garage. Will it be enough to warm up a two car attached garage?
Thanks for the reply, be safe.
Robert.
Tom; The garage is attached to the house, otherwise the barrel stove kit would be a good idea.
I like the local propane service idea better. There is a propane service company in Westbrook, but the will not refill tanks on a will call basis. The only way to get service is to do as you suggested. I just sent Ferrell gas an email. We'll see what happens.
Thanks, Tom, be safe.
Robert.
Here are more pictures of the pig trike, so named because I rescued the trike from a pig farm, kinda. Well, the trike was setting in a side yard, and the man did have pigs on his property, about a quarter mile or so away. My daughter was setting in the pickup when the smell hit her in the nose. "What's that god awful smell", she cried, literally. The man said "money". "Money", she's crying and slinging snot like a pro. The man took a deep breath and said "Yep, it smells like money to me". :laugh:Purple Pig 13.jpgPurple Pig 15.jpg
I'll add more after I chop the ice from the garage door so I can get inside.
Please do watch that Sunflower burner, the heat is nice within a few feet and with time the room warms up, but remember you still need some fresh air so you stay alive.
They would be great if they had a fan on them blowing the heat around, guess that is why I spent the money on the Mr. Buddy heater.
The real reason is I always back into them Sunflowers, or stand to close and catch my self on fire, yes it happened a few times. My nerves on the surface come and go, so some times I just do not feel any thing on my skin.
Just be careful and keep safe, oh and enjoy the new project.:D
lol about the smells like money statement...so true!
If possible, after some teardown, some parts could be worked on in the house, if careful.
Once knew a guy that overhauled a transmission in an upstairs bathtub.... landlord very PO'd!:xzqxz:
Good morning Andy;
As many broken windows as there are in the garage, breathing is not going to be my problem, moving around in my frozen Eskimo clothing is going to be trying. I've been checking on line, and I like the wall mount Catalytic heater idea Tom suggested. Point it at my daughters Ranchero in the other half of the garage for radiant heat. They should just sip propane from what I could gather from their advertisements.
It's too bad about your nerves, but I bet that comes in handy when your other half goes on the war path.
Be safe.
Robert.
Robert, since the garage is attached, I'd have a conversation with Ferrell Gas about the local codes and types of heaters that can be used in attached garages. Any heater with an "open flame" may have to be mounted X number of feet above the floor as gasoline and other combustible fumes usually dissipate at floor level. Also, make sure that you have a working carbon monoxide detector in the home for everyone's safety! (Not to mention insurance liability for the property.)
Another option is, if the house has natural gas already, look into the possibility of piping an overhead shop heater in the garage. Can't hurt the property value in the Great White North to have a heated garage space. :clapping:
Sometimes the "quick and easy" solution ends up costing more in the long run. "Pay me now or pay me later."
Too true on the working in the house. I would have the trike in my bedroom, putting it together, then after It is done, tare it apart, take it outside in the new summer environment and put it together, except, I live in my daughter's basement, and she's not as forgiving about me working on stuff in the house as her mother was. (I took that Honda from 40 years ago into the corner of the front room, disassembled it, took the body to a friend's house, and he chopped my CB 350 Honda frame for me. It had 6" over chrome downs, The neck was slightly kicked back, a king, queen seat, a spade looking sissy bar, it was stretched 2" behind the battery box, a shorter kick stand so it would lay over farther when parked, it had a Harley fat bob on it, and a Harley rear wheel laced up to the Honda sprocket. If you didn't look too close you'd think it was a custom miniaturized Harley. I had it for about 6 months, then traded it off to my brother in law for the 69 Charger.
She lets me do small stuff like starters, carbs, and stuff like that.
Be safe.
Robert. :dancing-santa:
stoney
