First 300 mile ride and impressions of my 2019 Tri Glide Ultra
Apr 6, 2016
538
479
Vero Beach, FL
Bob
Took delivery of my 2019 M8 (114) yesterday afternoon. Spent the rest of the afternoon and early evening waxing the shiny parts of the Scorched Orange/Black Denim trike and checked all of the fluids, tire pressures and rear shock setting. This morning, I headed out about 8:30 a.m. in 74 degree weather that eventually heated up to 92 degrees at about 2 p.m. Rode all different kinds of pavement as I traversed from one side of the Florida Peninsula to the other and then back again through the interior of the State.
I did this to be able to vary my speeds/rpm's throughout the ride on this first part of the 500 mile total break-in procedure prescribed by the MOCO (was limited to 3k max rpm for the first 50 miles and then 3.5k rpm until completion of break-in at 500 miles on the clock while all the while varying my speeds/rpms for potentially best break-in.
As some of you know, this is my third Tri Glide having owned: a 2016 103c.i. (14.5k miles); 2017 107c.i. M8 (7.9k miles) and now the 2019 114 c.i. M8 with 300 miles. I thought I would share early impressions of the new trike to help others discern if the improvements in the latest iteration are of interest to them in terms of possible purchase. Of course, I have only 1-day of riding but had just gotten off my 2017 2 days earlier.
The 2019 TGU with some of the added features is an overall better functioning trike IMHO. I didn't get that fastest color which is Black but I did get one of the neatest colors in this year's offerings which was the Scorched Orange/Black Denim combo. I had my selling dealer transfer all but the DK Customs Custom Lift kit over to the new trike. The reason that the lift kit did not get transferred is that the new suspension has the trike level and actually a bit higher in the back than my previous TGU's with lift kits. The steering is concomitantly easier due to the change in geometry and I think even a tad easier to steer than my TGU's with the Lift Kits. As Trampas retorts "All for now".
Here are my impressions in a somewhat organized hierarchical (what dat mean?) order to point out the improvements of the 2019 over the two previous iterations of TGU's that I have owned.
1. The new Boom! Box GTS infotainment center with the Gorilla Glass is light years improved over the 6.5 Boom Box era. if you use your Infotainment Center a lot for GPS/Trip Planning/Calls/Trike Status etc., the upgraded systems really take some of the sting out of the cost in upgrading to the latest model.
2. The 6-speed transmission on the 114 is the absolute smoothest one I have EVER had on a Harley. In addition to this, the formerly snatchy clutch engagement is a thing of the past and it is the most refined clutch that I have ever used on any Tri Glide. Finding Neutral was much easier on this machine than any of the other TGU's.
3. The 114c.i. M8 is smoother than either the 103 TC or 107 M8 and does not making popping sounds when decelerating. It does not appear to me to be that significantly more powerful than the 107 M8. I had the EITMS turned off and found that the idle is better at about 1,000 rpm as opposed to the 107 M8 which idled at 950 and tended to occasionally stumble leaving a light.
4. The Reflex Linked Anti-lock Brake System and Traction Control System are both different, a bit quirky, but more effective than anything that has come before it on the Tri Glides. It causes the brake lever feelings to change based on what the system sensors are reporting and it also at times makes some different sounds as the actuators do their jobs. I am not sure how these added features are going to play out when I am taking tight twisties up in the mountains? In Can-Am parlance, these systems are known as the "Nanny" and I am not that fond of relying on an engineers/programmers thoughts of how my suspension system should be responding and taking responsibility away from the rider.
5. The changes to the front and rear suspensions based on my uber precise, scientifically non-repeatable "butt-o-meter" findings suggested to me that the suspension overall rides maybe 30% softer and more compliant. It still seems like a fairly rough ride and I suspect that based on folks reports of the coil over shocks that places like DK Customs sells provide a better ride than this latest iteration of shock absorption? As I had mentioned earlier, the bottom of the installed optional rear bumper is approximately 13" above the ground and the trike does not have that drooping look/ride with much better muffler clearance than previous models.
6. I have heard through the grapevine that this new 114 M8 is likely sporting the 5th generation of oil pumps since the TGU's were equipped with the 103 "wet heads" in 2014 and supposedly, the latest oil pumps handle Stage 3 and 4 upgrades better, especially at higher speeds.
7. Did I mention that although slower than the Black trikes, the fit and finish of this top-of-the-line paint job with only one other color combo in the category is about as perfect as I have seen them painted. Harley also made the dash out of shiny plastic instead of the textured plastic and it looks really sharp (ala CVO's). Additionally, on the two most expensive paint jobs, the tank badges are flush with the tank and do not interfere with my knee placement. On my 2017 trike, I removed the big honkin' metal badges with strong fishing leader and got the adhesive goo off the tank with nary a scratch in the beautiful shiny paint underneath the two tank badges.
In our warm Florida heat, the extra displacement seems to translate into as hot or slightly hotter engine feel. I have a set of Love Jugs and DK Customs Floor Board Extenders on the trike to help ameliorate the deleterious effects of our significant heat cycles. Overall, as I was finishing up the ride, my thoughts were that I am glad that I migrated from the 2017 to the 2019 but I am not sure if the significant difference in prices/values completely warrants the upgrade? I don't plan to share those cost differences but rest assured that it was not as cheap as people like me would have liked :p
I forgot to mention one crazy thing. This new TGU represents my 100th motorcycle/trike (yep, it is not a misprint) since I began riding my own motorcycles in 1964. Pushing well over 400k seat miles and hope to add at least another 100k before I consider hanging up my handlebars.
Took delivery of my 2019 M8 (114) yesterday afternoon. Spent the rest of the afternoon and early evening waxing the shiny parts of the Scorch Orange/Black Denim trike and checked all of the fluids, tire pressures and rear shock setting. This morning, I headed out about 8:30 a.m. in 74 degree weather that eventually heated up to 92 degrees at about 2 p.m. Rode all different kinds of pavement as I traversed from one side of the Florida Peninsula to the other and then back again through the interior of the State. I did this to be able to vary my speeds/rpm's throughout the ride on this first part of the 500 mile total break-in procedure prescribed by the MOCO (was limited to 3k max rpm for the first 50 miles and then 3.5k rpm until completion of break-in at 500 miles on the clock while all the while varying my speeds/rpms for potentially best break-in.
The 2019 TGU with some of the added features is an overall better functioning trike IMHO. I didn't get that fastest color which is Black but I did get one of the neatest colors in this year's offerings which was the Scorch Orange/Black Denim combo. I had my selling dealer transfer all but the DK Customs Custom Lift kit over to the new trike. The reason that the lift kit did not get transferred is that the new suspension has the trike level and actually a bit higher in the back than my previous TGU's with lift kits. The steering is concomitantly easier due to the change in geometry and I think even a tad easier to steer than my TGU's with the Lift Kits. As Trampas retorts "All for now".
1. The Infotainment Center with the Gorilla Glass is light years improved over the 6.5 Boom Box era. if you use your Infotainment Center a lot for GPS/Trip Planning/Calls/Trike Status etc., the upgraded systems really take some of the sting out of the cost in upgrading to the latest model.
4. The linked brakes, traction control, and a two other features of this performance ensemble are both different, a bit quirky, but more effective than anything that has come before it on the Tri Glides.
Thanks Bob for the review. BUT DANG she sure is PRETTY
Good looking trike or should I say a great looking trike, I debated on a 2019 they had in black but chose the 2018 instead, after a few threads from you and others on the 2019 maybe I made a mistake. I know I got a better deal on the 2018 and couldn't get together on price for the 2019.
Enjoy the new ride
All for now Trampas
Indeed they do
The newest pump has an all new seal that is supposed to help
2019 Trike
Thanks for a GREAT review....... I want that same color, dealer has one, but we have NOT AGREED on terms yet!
CONGRATs on your NEW RIDE!
:clapping:
Enjoy the new ride
All for now Trampas
Trampas, As I stated in my opening remarks, " Overall, as I was finishing up the ride, my thoughts were that I am glad that I migrated from the 2017 to the 2019 but I am not sure if the significant difference in prices/values completely warrants the upgrade?"
Because of the delays in getting the paint formulation correct on the 2019 Scorched Orange/Black Denim paint, most Harley dealers are reportedly not going to be able to receive all of this color that they would like. The difference between a 2019 Black TGU and the color optioned Orange is a whopping $2400 just for the paint colors and a flatter profile set of tank badges.
If you compare the 2018 list price on the Black TGU to the two-toned 2019 color option, we are talking a whopping $4000 just for the paint/and model year feature differences. That coupled with the deals that some dealers are likely making on left-over 2018 inventory would suggest that the price/value comparisons become tilted toward the 2018 IMO. It also depends on how much you ride and how often one is prone to change out their rides which then brings depreciation schedules into play.
The dealer was very accommodating (did I mention that I really appreciated working with all the staff at Treasure Coast Harley in Stuart, FL?) and was willing to transfer my accessories that originally cost me about $2k which sealed the deal for me. Had I needed to reload on the exact same accessories, I would not have migrated from the 2017 I owned. I don't think that you made a mistake whatsoever.
In another thread I had started a while back, I had said "Meh" to the 2019's. Do we really need complex traction control systems? Do we really need fancier Infotainment systems? Is the 114 M8 significantly better than the 107 M8? Is the suspension system night/day better than the previous iterations? The answer to these four above questions is likely "Not really". So, when making a significant buying decision and weighting those variables, it is likely that your choice to get a right-priced 2018 may have been the smarter move? As you are prone to say, "All for now".
Capt Bob, I found this to be a very good write up of the the 2019 HD TG, it's all there, the words, consider writing for some m/c magazine, not kidding. You've certainly had your experience on the Harley. I ride the GW Road Smith, and and I can tell you from my experience, the coil over shocks don't get any better in the smooth ride department, they are what the are. The TriGlide must be one tough machine, I read all about Kevin's long road trips, two up, fully packed, all kinds of weather, impressive!
Bill
Very nice Bob. That color is absolutely awesome. Say what you will about Harley but they do have some great looking paint schemes.
Because of the delays in getting the paint formulation correct on the 2019 Scorched Orange/Black Denim paint, most Harley dealers are reportedly not going to be able to receive all of this color that they would like. The difference between a 2019 Black TGU and the color optioned Orange is a whopping $2400 just for the paint colors and a flatter profile set of tank badges. If you compare the 2018 list price on the Black TGU to the two-toned 2019 color option, we are talking a whopping $4000 just for the paint/and model year feature differences. That coupled with the deals that some dealers are likely making on left-over 2018 inventory would suggest that the price/value comparisons become tilted toward the 2018 IMO. It also depends on how much you ride and how often one is prone to change out their rides which then brings depreciation schedules into play. The dealer was very accommodating (did I mention that I really appreciated working with all the staff at Treasure Coast Harley in Stuart, FL?) and was willing to transfer my accessories that originally cost me about $2k which sealed the deal for me. Had I needed to reload on the exact same accessories, I would not have migrated from the 2017 I owned. I don't think that you made a mistake whatsoever.
I agree with your thoughts, I did get a good deal on the 2018 and happy with the decision I made, I better be anyway LOL, I don't put the miles on like alot of guys in here, but this will be my last trike, well maybe I shouldn't say that:D:D, just never know what I will do
All for now Trampas
Finally got the 2019 TGU past the break-in 500 miles
Wahoo! I was out of town for three days so hadn't had an opportunity to finish the 500-mile break-in on the 114 M8 TGU. Well, I can say that this particular hurdle is now complete. I did try smoothly partially winding it out and as expected with peak torque listed at 3250 rpms, the run-up to 4500 rpm did not produce much extra punch but did nicely sound a bit more "throaty".
Our 2019's come with hydraulic preload rear shock adjusters instead of air and trying different settings riding solo did not change the overall ride. As others have reported, the new front forks have a bit of a sharper jolt over rough pavement and the rear shocks do not seem to be particularly sensitive to changes in settings that correlate with a difference in ride comfort. I have my rear tires set at 22 pounds and will try them at 21 to see if that makes a difference?
I was truly lucky to have snagged the Scorched Orange/Black Denim paint job trike because I have been advised that Harley will not be making as many as the market would likely want to have. Sooooo, if you are on the fence and your dealer has that color and it is calling your name, I would suggest jumping on it. It will be the perfect color for each Halloween that you own it.
Overall, with the subtle and not so subtle (i.e. clutch and transmission smoothness/braking/traction control/Infotainment system) upgrades and slightly smoother running M8 engine, I am quite pleased with the purchase and have not experienced one moment of buyer's remorse which says a lot about how much I like the trike and how I don't miss that smokin' hole in my checking account:D
Have accumulated 620 miles on the 2019 and each ride, I am loving it better. Unfortunately, I have a date in 11 days with an Orthopedic surgeon to repair a torn rotator cuff that will likely keep me off this beautiful trike for about 3 months just when the riding season is the best in South Florida. Oh well, I am going to finish the initial 1000 miles, do the 1k service and then put it away for 3 months (sob). I guess you folks in the colder climates are not shedding any tears for me.;)
Have accumulated 620 miles on the 2019 and each ride, I am loving it better. Unfortunately, I have a date in 11 days with and Orthopedic surgeon to repair a torn rotator cuff that will likely keep me off this beautiful trike for about 3 months just when the riding season is the best in South Florida. Oh well, I am going to finish the initial 1000 miles, do the 1k service and then put it away for 3 months (sob). I guess you folks in the colder climates are not shedding any tears for me.;)
You're right no tears.
Congrats on the new ride. Great report. I had that surgery yrs ago & I hope you a quick recovery, worked great for me.
I’d be willing to put some miles on it for you.:Santa:
Scorched Orange
I’d Jump on that tooooo.......I was in Las Vegas this past week and both dealers told me that there are NO SCORCHED ORANGE trikes on the entire West Coast, although my dealer in Sacramento HAD one and immediately SOLD IT!
Love that color.........hopefully HD will ship more out!
:clapping::laugh:
HD, the masters of merchandising, you'd think they would build a lot of this popular color.
I know it seems kind of weird to create an artificial scarcity. Although, it is the way that they can add $1800 over the black trike with great customer acceptance of the inflated price and also be able to advantage some of their selling dealers to get over list price. If I didn't like mine so much, I would put it up for sale and flip it:qpnmt:
They have put the Scorched Orange/Black Denim on 6 other high-end models for this model year. I keep looking at the paint on mine and it really is a beautiful and lustrous color. It is the perfect color for Halloween! My pumpkin colored trike!
1000 Mile Service is Complete
Well, I have been riding the wheels off of the 2019 and performed the 1000 mile service over the past two days. I am pretty slow and methodical and it takes me about x3 longer than any Harley service tech to do a 1k service but I know that everything is done exactly to the book. The only check item that I find very odd is one where it asked you to assess if there is any moisture in the brake fluid? If you crack the system open, then it seems to me that you are introducing moisture?
I could be wrong and am going to have to check this out with a dealer to see how they are handling this. I understand why Harley included it because of the moisture in the brake system recall debacle but I am not sure what they really want us or a tech to do? The other interesting thing is that in the owner's manual, it calls for Formula+ for both the tranny and the primary. I have ALWAYS used only Formula+ because I never had confidence that SYN3 could do it all?
It didn't make a lot of sense to me that it would be good for all three holes and now we are seeing, likely in part due to oil migration issues, that Harley is no longer recommending SYN3 in all three holes on the 2019 TGU's at least. On my 2017 TGU, I used only Formula+ for my tranny and primary and had zero issues with oil migration which may or may not have anything to do with the type of fluid we are using? Here is a picture of the trike in "full up position" mode to access all of the goodies underneath the trike like having to check the torque on the oil pan bolts which is only done at the 1k check.
Took delivery of my 2019 M8 (114) yesterday afternoon. Spent the rest of the afternoon and early evening waxing the shiny parts of the Scorched Orange/Black Denim trike and checked all of the fluids, tire pressures and rear shock setting. This morning, I headed out about 8:30 a.m. in 74 degree weather that eventually heated up to 92 degrees at about 2 p.m. Rode all different kinds of pavement as I traversed from one side of the Florida Peninsula to the other and then back again through the interior of the State. I did this to be able to vary my speeds/rpm's throughout the ride on this first part of the 500 mile total break-in procedure prescribed by the MOCO (was limited to 3k max rpm for the first 50 miles and then 3.5k rpm until completion of break-in at 500 miles on the clock while all the while varying my speeds/rpms for potentially best break-in.
Well, 10 days after receiving my new 2019 Scorched Orange/Black Denim TGU with 5 miles on the odometer, I have put on 972 additional miles and completed the 1000 mile service here at the house with supplies obtained from my selling dealer. Although very new to this latest iteration of Tri Glides, it is my third one and I am thinking that I would want to change the original hierarchical ordering (above) of the 2019 features in contrast to my 2016 and 2017 TGU's that I traded each time to get up to the 2019.
1. The 114c.i. M8 engine is a sizeable improvement in terms of overall smoothness of operation over my 2017 107c.i. M8. It idles better, is smoother running through the gears and transmits less vibration to the trike while running down the road. It does not seem to be more powerful but is pleasantly smoother than the TC 103c.i. or the M8 107c.i. After break-in, I smoothly brought the RPM's up to about 4k plus and the pipes have a throatier sound.
Additionally, the 114 seems to make considerably less internal mechanical noises. Not sure why? From what I have heard through the grapevine, the engine may be sporting the 5th generation of oil pumps (by part number) and likely will have a positive affect on engine functioning as compared to some of the earlier iterations of the oil pumps.
2. I really like the Reflex Linked Anti-lock Brake System and the way that using either the front or back brakes partially activate the other sets of brakes. The braking is the most positive that I have experienced on a Tri Glide. I think I will also like the Traction Control System when I ride in wet weather on twisty roads but have yet to experience that aspect of the new features.
3. The Boom! Box GTS Infotainment System on the 2019 is so much faster, intuitive and displays so much more information in a very pleasing format that the old 6.5 Boom Box should never be mentioned in the same conversation when it comes to ease of use and utility.
4. The lack of a snatchy clutch (now very smooth engagement) combined with an ultra smooth transmission makes for pure joy in rowing through the gears up or down. Finding Neutral is no longer the pain it was with the two previous TGU's.
5. Although a purely aesthetic issue, the Scorched Orange/Black Denim paint job is the nicest I have ever seen on a trike. Of course this is a personal taste thing and others may actually find the colors a bit too gaudy or too retro?
6. The suspension, both front and back is better but my butt-o-meter tells me that it remains only about 30% more compliant and comfortable than my 2017 with no fancy front forks and the former air shocks. The 2017's shock settings were easier to adjust by just taking off the right side cover and using a Harley shock pump to get the "goldilocks" setting.
On the 2019, the seat is secured by a long bolt with a knurled head but Harley has the bolt canted almost against the chassis of the trike actually making it a bit more difficult to get the bolt started. I found that being right handed, it was easier for me to manipulate the seat from the right side of the trike with my left hand moving the seat around and my right working the long bolt into the seat stay hole and the threaded hole in the trike frame.
I am very tickled that the new suspension takes out the sagging rear ends that were a hallmark of the TGU's until 2019. The bottom of my mufflers have 7" of clearance above the ground in the stock configuration. I find that the change in geometry makes for possibly the lightest stock steering inputs of any previous Tri Glide.
Well, if you compare my initial impressions with my 1k impressions, you can see that my weightings have changed with usage of the trike. The bottom line is that I more strongly feel that I am glad that I got to sample and own Harley's latest iteration of the Tri Glide Ultra. Is it perfect, hell no. Is it fun, hell yes!
Capt. Bob (or anyone else that might know),
Any idea(s) on why the clutch is smoother and has lost the tendency to lurch compared to the earlier M8's?
  • Like
Reactions: MDO
Just my guess, They Harley got tired of the complaints [ie stalling] and preloded the new shift lever...Like some after market companies sell..:Shrug:
[Hogleverage.com]
I would bet it is due to the recall of the 17-18 models that have a potential problem with the slave cylinder
The 19 models should ALL have the NEW cylinder already JMO
  • Like
Reactions: MDO
Jack, I think you are likely correct. It is kind of weird but if I slightly pull in the clutch lever, I get a pulsing feeling in the lever that I never felt before on the other trikes.
Bob
Trike down
