New 2019 Tri Glide!
Marcus
20+ Posts
Mar 7, 2015
28
25
Central California
Why? I don’t know. It just seemed to be the thing to do, but I am glad I did.
I went from a 2016 to 2019. Bought it at Bakersfield Harley Davidson. Good people to deal with. I live about an hour and forty-five minutes away on truck infested Highway 99 down the California Central Valley. I wanted to buy it locally but couldn’t find one in the area.
Unfortunately, after buying it, I was called out of town on business. I got back a couple of days ago and have been able to put only about 25 miles on it.
Initial impressions:
1) More grunt, pull and power. I’ll know more after completing the break-in process.
2) The rear shocks appear to be somewhat better than the 2016 shocks, but not much. I need more time to search for the “sweet spot” setting.
3) It is a pain in the posterior orifice to change the rear shock setting. The seat has to be removed to get to the adjustment knob. It is not difficult, but it’s a PIA to remove the seat every time.
4) While adjusting the shocks, the knob feels like it is turning a cable. Based on what I’ve seen so far, the lines from the adjustment unit to the shocks unit appear to be hydraulic. The lines also appear to be connected to the shocks via banjo bolts.
5) Front suspension seems stiff.
6) The Boom Box GTS is fantastic. Much easier to see and use.
7) The brakes appear to have more stopping power than the 2016 brakes. I like the linked brakes. You still have to use both the front and rear brakes’ but the linking appears to give it better and smoother stopping power.
8) The traction control button is in a weird place and seems like a waste of space on the handlebars. I keep hitting it while trying to get into reverse.
9) I don’t like the new reverse on the started button, but it works!
I haven’t decide if I’m going to give the new trike a nickname, but if I do, “Big Dawg” or Trike-a-Saurus” are at the top of the list.
The trike goes in next week for a new $eat, $tage 1 kit and wheel$ & rim$.
New 2019 Tri Glide! – Addendum
The heat coming up off the exhaust while stopped (stop lights & sign, parking idling, etc.) appears to be about the same as the 2016. No difference. I am going to look into the new Coolflow Fan to see if it will help.
Beautiful, congrats! Don't know about the Cool Flow fan, but Love Jugs work great keeping the heat down. If you don't have an oil cooler, definitely a must imo. DK Customs has a Jagg aftermarket oil cooler designed for tri glide.
2019
Very nice and CONGRATS!
Please keep us updated on your new ride.........I’m still debating on an update
and looking for reviews/comments on the ‘19s.
:clapping:
Thanks for the review, I'm thinking on a 2019 or get one of the 2018's they have, don't really have any 2019's in did see one, depends on the deal I can get, they have at least 5 2018's in stock.
Get the love jugs, better cooling and haven't heard anything about the coolfan from harley but looking at it I don't see how it would work that good, just me I guess but the love jugs have very good reviews.
All for now Trampas
Very nice! I have a 17 Freewheeler & the Cool Flow fan will help with the heat on the right side by the floorboard, mainly coming from the cat. I leave my fan on all the time. I did notice when you get past break-in, the heat issue seems to get a little better. I'm up tp 6,500 miles & the fan helped, getting DK Customs 1.5" deluxe tank lift helped & changing to Lucas 20w50 full synthetic motorcycle oil helped the operating temps also, along with improving the shifting.
Keep in mind, that Cool Flow fan is not for the engine, it's for your comfort.
New 2019 Tri Glide! – Addendum #2 / 34 Miles on the Clock
1) Definitely have to back off the rear shocks preload. I have it set based on my weight as recommended in the manual. Too stiff as recommended. This means I have to take the @#$% seat off again. I will also probably bleed off a couple pounds of air pressure from the tires.
2) The clutch pull is stiffer than on the 2016. It takes more grip strength to pull it in and keep it in, such as when sitting at a stoplight. This is probably due to stiffer clutch springs to handle power from the bigger engine. (I stayed at a Holiday Inn last night, so I am fully qualified to make such assessments.)
3) The engine starts more easily and smoothly than the 2016. No more lagging or pausing while turning over to start.
4) IT GOES INTO NEUTRAL MUCH, MUCH EASIER THAN THE 2016. It goes right in! I haven’t missed it once!
5) There is almost no backlash in the drivetrain at low speed, such as in parking lots and through residential areas.
6) Nitpick: The batter tender plug is below the left side cover and under the left passenger floorboard. It is a little more difficult to get to (I have to bend over further to get to it) and, if one is not careful, it will hang down on the left exhaust pipe. I am going to look into rerouting it to a more convenient location.
7) The gear set seems to be shorter on the 2019. The engine appears to run at lower RPMs than the 2016 at the same speeds. Either that or my helmet is too tight.
The battery tender lead is inconveniently located low on the left side
Traction Control switch on the left grip.
I left mine on the left side just like yours, but I used a zip tie and secured it better to the frame so it didn't have a chance of getting on the exhaust, worked for me.
All for now Trampas
Congrats on the new Trike. Appreciate the ride review and your comments....seriously considering a retrofit of the new suspension system on my TG. Happy to hear it's a big improvement. ThumbUp
bought the same color four days ago. 200 miles so still in the break-in and so far very happy. Traded in a 2014 Triglide.
2019 Tri glide. Same wife and I think it is the best color.
We chose the same color. I think it is the best. I have noticed several things that you have Found and some things I have found. great to see your post.
Reverse
I traded my 2018 Harley Trike in for a 2019 Harley Trike. I want to go to a solid color instead of the two tone. Yeah it is a little getting used to having the Reverse button on the right side now, I can see how you would hit the traction button on the left.
Has anyone installed a CB n the 2019 Trike yet. Can't seem to find the correct switch pack that has the reverse/warning/start button labeled correctly.
Rick......Welcome to Trike-Talk.......:clapping:....
Hey Rhino 2, thanks for the welcome I'm hoping to find some info for my Trike as well.
I was looking at one person's trike here that installed mud flaps without drilling holes...hummm how did he do that it's very clean looking. I'm impressed
That's purdy! Enjoy your new ride. Now that my '14 is paid off maybe time to trade. Not!
New 2019 Tri Glide! – Addendum #3 / 65 Miles on the Clock
I am still working to find the "sweet spot" in the rear suspension. I backed off the preload a couple of turns. It is better, but I'm still not happy with it. There is no rebound adjustment. I going to try backing off the preload another turn or two and airing down the tires a bit, but the lack of rebound adjustment may prevent getting the ride where I am happy with it.
The trike is in the shop at the moment for upgrade$:
  • Tour-Pak Luggage Rack
  • Rear Bumper
  • Enforcer Chrome Wheels & New Tires
  • Screamin Eagle Street Cannon Slip-On Mufflers
  • Screamin Eagle High Flow Air Filter
  • Screamin Eagle Pro Street Tuner
  • Tallboy Seat
I hope to get it back tomorrow or Wednesday.
Wasn't me but I remember he used industrial strength Velcro. OP says it works! key was to have the surface very clean when applied the sticky back to each piece.
I dropped off my 2019 Tri-Glide at the dealership early last week for a number of upgrades/accessories and got it back Friday. The upgrades/accessories are listed in Post #26 in this thread. I am especially pleased with the new Screamin' Eagle Street Cannon Mufflers, high-flow air cleaner and new tube (downloaded, not dyno tuned). There is noticeably more power with the Stage 1 kit with no decal popping (and the trike no longer sounds like an angry lawn mower).
Ron A
