Any of you have any updates on your new running boards yet? Mine are in, just not on:-(
One last thing if anyone is going to install the Legend air suspension or already has it installed the compressor that mounts under the bike may need to be relocated
Looks great.. were the wires long enough to reach from the handle bars back to the truck??
There is no drilling of the fenders with the New Hawg EFX boards they use two sided tape now and caulk.If they mount similar to the Champion boards the left side will have to be removed if you ever need to remove the primary cover. You still have access to the clutch inspection cover for primary oil changes.
The critical part of the installation is making sure you have the mating surfaces between the boards and rear fender perfectly aligned and clamped in place before drilling the mounting holes in the fender.......assuming they mount the same as the Champion boards.
Yes. They have metal supports under the boards that get installed.Are the boards for the Tri-Glide weight bearing?
