Clutch question?
May 8, 2018
3
6
Wichita, Kansas
:xzqxz:Twister City only had one Freewheeler, when I tried the clutch it felt a lot heavier than the clutch on a Street Bob I tried. Both were 2018 with the same engine the 107 Milwaukee-Eight. It seems to me they should feel the same on the lever. Also I had a hydraulic clutch one time that had less pull when the engine was running what about the Freewheeler? Is there a lever set that would give me a better leverage?
:xzqxz:Twister City only had one Freewheeler, when I tried the clutch it felt a lot heavier than the clutch on a Street Bob I tried. Both were2018 with the same engine the 107 Milwaukee-Eight. It seems to me they shouldfeel the same on the lever. Also I had a hydraulic clutch one time that hadless pull when the engine was running what about the Freewheeler? Is there alever set that would give me a better leverage?
There are after market Adjustable levers.....Do you have problems with your hand.
IE; Artritis......:Shrug:
Hand Problem
Yes I do it is a combination of Osteoarthritis, Stroke
and Dupuytren's Contracture. The last is a inherited disease that causes tissue build up under the skin of the hand. The hand gets stiff. I can use the hand just not a lot of strength. When I shoot, I have to rack the slide with my right hand then transfer the gun to my right hand. I do that so fast that one instructor did not notice it until 4 hours into the course. The problems are all with the left hand and have not gotten worse in the last five years. I could handle all the controls the clutch was very stiff.
louisianaJack
