Having a problem with my reverse; engine running, in neutral, press reverse button and wait for it to light up steady. Once it does all I get is a clicking from the RCM solenoid. Breaker not tripped, checked voltage before and after breaker and RCM solenoid while pressing the reverse button and getting a little over 14 volts.
Pulled reverse motor and bench tested it and it seems to operate fine, checked voltage at the reverse motor connections and still getting a little over 14 volts with the motor running. Cleaned all of the connections and reinstalled, same thing just a clicking at the RCM solenoid.
Any ideas?
Thanks in advance for any suggestions,
Red
Any ideas?
Red
