Post Your VW Trike Pics
Re: Post Your VW Trike Pictures HERE
Trikes4ever, Bob,
Jerry and I linked up early on - he was buying frames and parts from Nova to get started and in return for extra good pricing was going to produce some options that could be marketed with and as Nova products. He and his partner built a few of the trikes and developed several fiberglass components including the rear cover that I had expressed an interest in and he wanted as well. So actually the one (or two?) that he built and the one prototype at Nova were the same mold.
The silver one that Nova built was purchased by almost the first walk-in customer who saw it, and as I recall it went only about 75 miles north of here to Shelbyville, TN. on the day it was completed (I didn't even get a test ride). The 9/11 disasters just happen to significantly affect Jerry's mainstream (other than trikes) business operations and he had to give that his full attention for a while so the trike work sort of slowed or stopped. I've been remiss in keeping in touch with Jerry (I think I'll call him in the next couple days) so I don't know if he's still doing any trike endeavors. He offered me the molds a year or so back, but I wasn't sure if I would ever need them.
His website is still up, although obviously months or years since updated - I don't know if he still has anything going on. Yea, maybe I need to get in touch :jerry: and give him a shot of enthusiasm again since I've retired from my other business pursuits and might want the molds after all to get me or him or us going again, who knows.
Of interest to you, Bob, is that the few frames he started with were mostly, if not all, Digger style (with Nova modifications - shifter system, pan, controls mounts, shock mounts, etc.). You can still look at his trikes at DragonTrikes.com.
Regards from Alabama
Loner
Hi just signed-in...
First one is VW Fecht 1 I use to ride last century (literary). The rest is project I am planning to finish before spring. Wil keep you updated on progress.
Here is the newest pictures of my project. Still need to plumb and wire it, as well as figure out a front brake [Illinois law-dumb!] Oh well, still in the build stage. Havin' fun. And, last but not least, my camera shy welder/painter/pinstriper, the infamous Garld 'Toby' Jones.
Never get tired of looking at different trikes and the VWs are some of the coolest! Put your pictures up please.
The Trike that I take is made based on Type-1 in 1973 now.
The engine is put, substituted in April, 2010, and it is good now.
Well i suppose i better post something instead of just lurking! Some nice VW's in here ThumbUp
Are work in progress pics any good ignore welding its rough and to be re done lol
The frame i Purchased
Getting on with the build seat bases not finished yet
For your amusement From OZTRALIA, Wideglide wildcat 2011 new release and the convertable perfect for the outback or desert use where temps hit 65 celcius here
I absolutely don't want to set myself to be flamed here, but in reference to the tow bracket in the utube video (and the many similar deisngs that mount solidly in a receiver), while it will work great for a two-wheeler (because the bike frame is able to lean as corners are taken), the tow bracket needs to have a horizontal pivot built into it to tow a trike. If the front forks are tied and held upright it will put serious stress on the trike neck, and the more rake the more the stress. It may not break anything on the first few uses (depending on turns), but a few tight figure eights with the tow vehicle and something's going to be damaged on a trike.
Same design with a horizontal pivot in the front area (where a hitch ball would normally be) will work fine. Like I say, not my intent be flamed or start a controvery, but when a trike turns a corner, something's got to lean and when driving a trike that's the front forks - if they are locked vertically something's going to break [sooner or later]. Turn your trike steering to full lock in either direction and look at how the front forks lean - and then imagine forcing that front end vertical with straps while keeping it turned.
I know this is often not an evident parameter to many trikers, but I've designed and built them for forty plus years and have faced many of the geometric issues and horrors of trike engineering (learned about 'trail' back when we didn't even know what the term for it was).
Warm regards and happy triking!
Hi
This is what I am building mid engine no cooling tin - 345 wide tyres 15 x 12 wheels.
Building everything myself including frame.
Have parted engine from gearbox by 6" so that the wheels could be made very narrow. Each axle is only 6" long. Building extended bell housing to house clutch mechanism and slave cylinder which will all be hidden in side the new bell housing. Starter motor will be moved to the underside.
I am using CBR 900 carbs split in two.
Another picture for you:
p.s. Front end is Harley fat boy. Will be replacing front wheel with an 80 spoke skinny 21" wheel. This should exaggerate the wide rear wheels nicely.
Final trike will be full chrome and gloss black.
Here is a close up of the rear wheel / brake and shock. Still designing and building so just held in place for now.
You will see how short the axle is.
One thing I have noticed is that I have used an after market Harley shock but I am surprised how stiff it is. I cannot move it. I am hoping that I can once it is installed and I adjust it.
Designed and fabricated handle bars last weekend. Long and fat. Still need to insert inch bar at ends to take grips. Once complete will be fully chromed.
I'm new to this forum. I bought my 1st trike a few weeks ago (1971 VW). It needs a little carb work but it is licensed and does run.
[/ATTACH][/ATTACH][/ATTACH]View attachment 3657new brake pedals.old ones were ,,,blah.new ones quick look.lousy at engraving.turned out pretty good though.also got my fenders repainted and on.the last one is how it looks currently:D,,,dont mean to brag[yes i do ]but,,,,
New guy with a trike. Here's the pics...
Also ride an "84 Goldwing with Vetter Terraplane sidecar
Kickstand_Korner
