Installed a hitch on a Tri-Glide yesterday
Jun 15, 2013
9,401
9,920
Red Banks, MS
Yesterday I installed a hitch on a Tri-Glide.
Photo of receiver, hitch and electrical. The electrical is made up on HD compatible connectors, a CanBUS module, an isolator, and connection to the trailer.
Receiver installed...bolted to the two cross-members below the trunk.
Hitch installed. Held in by a standard pin and clip. There is also a set-screw to keep it from rattling in the receiver.
Electrical all installed...it fits up under the passenger section of the seat.
Hooked up and working with a trailer.
Looks good Kevin. I'm really thinking about installing a hitch on my Tri Glide as I had one on my 2009 Motor Trike conversion.
What brand of hitch is that one Kevin?
The one thing to be aware of, a hitch on a HD is going to almost assuredly void the warranty...not much of a way around that one.
The hitch is a one-off, built before they were readily available in the aftermarket.
I have my wiring harness set up to unplug within minutes and i can have the hitch off in about ten minutes if i need to take it in for warranty work.
Almostagamer
