Khrome Werks 2+2 Stretch Handlebars are on!!! Photos Added
hardwickbv
1500+ Posts
Gold Member
Mar 5, 2017
1,903
654
Mitchell, IN
Bob
Took my 2017 Tri Glide Last week in for a couple warranty issues, decided while it was there I would have them install some wider handlebars to help my back out some.
Was looking at the Khrome Werks and like the options I was seeing so the dealer contacted them and they (KW) suggested the 2+2 Stretch bars PN 0601-2650 indicated that they would fit and should not need extensions.
Fast forward to yesterday the bars came in and the tech said "these won't work" so after a decent amount of frustration and the dealer contacting KW again and receiving verification that they would fit I told them to put them on.
Hopefully we will know later today whether they will work or not.
The only catch now may be the fact that I have a 2" tank lift on that may cause a problem.
Bob
Bob
Mine worked. You should be good. But mine were 2x2 narrow.
It seems some dealers if it don't say HD (High dollar) in the item number the parts don't fit. That is purely for profit margin I believe I would look else where for my parts and service just sayin. I chose the 2+2 Wide Sweepers for the convex curve to clear the fuel tank, 2" deluxe tank lift and air deflectors
Just checked Khrome Werks site 0601-2650 is not a good number on their site that I could find. I may be wrong I have been before.
They are on
Just got back and they look and feel great!!!!
It is much easier to turn and I feel like I am not having to lean forward as much.
They are on the Krome Werks website as
1.25" 2+2 Stretch Bagger Handlebar with ETC for 1997-2017 Harley-Davidson[SUP]®[/SUP] models
KW Part # 300302 LeMans Corporation / Drag Specialties 0601-2650
Mid-USA Motorcycle Parts 49-1881
The dealer did use extensions on the wiring, stated the stock wiring was 2" short.
Here are some before and after photos
Before
After
Before
After
Before
After
Before
After
Took a test drive
Took it out tonight for about a 40 mile drive on some fairly twisty and hilly roads that I ride to work every morning. The first 15 miles has several 45 and 90 degree turns as well as steeper hills with turns on them.
I could really tell the difference with the new bars. The statement that it feels like I added power steering is true. I no longer have to lean into the bars to get the trike to turn and I don't feel like I am leaning forward all the time as I was with the old bars.
Going to give a pretty good workout labor day weekend!!!
Thanks for all the comments
Bob
Bob
Glad these are good for you. Fred
What is the order number for chrome werks for narrow bars will they work on a 2008 ultra classic?
Thanks Greg
Check out Khrome werks website or give them a call. KW PN 300-518 may be the number you are looking for. They are really helpful with questions, and yes they will work on your 08 ultra. I used the wide ones to gain leverage. :D travel safely Fred
e
I guess the $800.00 installed that I paid for HeliBars was not as costly as it seemed. They were installed at Biktoberfest in 2013.
That was a great deal you would be hard pressed to get that again. Those deals are out there right place and right time it could happen tomorrow. I did my own for less than $250 plus tranny oil. ;) Fred
Looks like a good winter project for me. If I'm slow at it, it won't matter. I won't miss opportunities to ride.
I like that in the OP's pics his arms looks like he can still lock his elbows. I see riders on all kind of bikes with there elbows bent close to 90°. I really don't see how anybody could ride like that. I know they handle it but I had a bike that put my arms in that position and I dropped the bike a few times. I had to change the bars.
ETA: Oh, and thanks to the OP for the pics. They helped me a lot.
My indy would only give a ballpark estimate because he said they are all different. He said barring something crazy it would be 2 or 3 hours. Don't know exactly what his rate is but I know it is less than the dealer.
With some common sense, and a six pac , you can change them on your own. Only problem I had was with the DBW conector pins :gah: However u-tube was my friend.:clapping:
I agree but I was thinking if I do my on 5000 mile service, I won't feel bad about paying for the bars. :Coffee:
Not That Difficult
Added LA Choppers 12" Twin Peaks, Namz extensions and Alloy Art Bushings for $302. total.
About 6 hours as I took my time and labeled connectors. On 2015 and older you need to remove the TBW connector to get it through the bars but it was only a matter of patience.
Be sure you have a torx 27 in your set.
I am trying to decide if I want the narrow or the wide. I would like to ask the OP and Fearless how tall they are. I think that might help me decide.
Thanks, Bob
ETA: Actually anybody that wants to say which set of bars they have and how tall they are would help..Thanks again. I am 6 ft.
I am 5' 10". I went with the wide or stretch bars because I have 2 discs fused in my neck. With the stock bars my arms were in a position that would cause my thumbs to go to sleep on longer rides. Also I was having to lean in to turns causing the area around my fusions to become aggravated. The stretch bars are 4" wider than the stock bars and with them being 2" closer and 2" higher my arms are in a much more comfortable position. My thumbs no longer fall asleep unless my neck has been aggravated by something other than riding. The best part of them being wider is it is considerably easier to turn, in an earlier post I compared it to having power steering and that is still true.
Ride Safe
Bob
Ride Safe
Bob
Thanks, sounds like they would have worked for me. But before I read your response I called Khrome Werks and they recommended 300517. They are also a little wider. I went to Dennis Kirk and their site said they wouldn't fit my 2017 Tri. After looking all over the forums, it looked like they should work. The tech at Dennis Kirk looked at everything and said that it looked like they should work. I ordered them. Fingers crossed that they will work.
Thanks again,
Bob
