spiritdream
One of the Originals
Just brought home my "new" 2005 GL1800 with Hannigan kit. We discovered that it still has the kickstand & center stands attached. Is this normal??
Does anyone have a Motor Trike GT3 kit on their SILVER WING...if so...can you tell me the in and out of maint.
Ron,
There's really not much in the way of maintenance on that kit. Lubricate the drive chain (frequency will depend on type of chain lube you use & riding conditions), adjust chain slack as needed. Any time you adjust the chain slack it's CRITICAL that you verify the front & rear sprocket are properly aligned; failure to do so will lead to accelerated wear of the sprockets. If you ride on rough roads, I'd recommend checking fender bolts ever so often also (if you notice they want to work loose, you could remove one at a time & add low strength loc-tite to them & snug back down. Rear tire pressure should be approximately 22 psi.
