Stock Air Box Back On Re-Did, Re-Rout EBS Catch Can Set Up
Mar 5, 2015
474
366
Bakersfield, CA
Bill
I installed the Stock Air Box back on our 2017 trike today. I also re-installed the (EBS) catch can set up I had previously used. I decided to re-rout it out of the air box and re-rout it under the frame.
I think it turned out well. I had to make a clamp and mount it to the existing exhaust clamp (see pic hose running through clamp).
I had to drill a small hole in the stock air boxs bottom for the hose to exit and rout the path of the hose not to touch anything and not to get melted.
Ride Safe All, :)
Bill G
Sorry your stage 1 air cleaner didn't work out for you, surprised you didn't take it the dealer for a download
All for now Trampas
All for now Trampas
Trampas,
My 2017 trike runs very well stock. For me the stage 1 was about looks and an experiment. My bubbly will buy the stage 1 from me for what I paid for it. He builds high end hot rod Harley motors at his engine shop.
On the 2017 models with the 107 M8 there is no more downloads like on previous years. You have to now buy the HD Screaman Eagle EPA legal street tuner or an aftermarket tuner to tune the 2017 M8 engines.
I did not want to spend $300.00 to $400.00 dollars to get that little extra. As said I find the 2017 trike with the 107 M8 to run just fine stock plenty of power.
Also I can live with the looks of the stock air box. Plus I can now use my catch can mod.
Ride Safe My Friend,
Bill G
You would have to buy a aftermarket tuner since the HD one is not for triglide, I looked it up one time when I was talking to the service department and they mention that one from harley. I looked at online and it does not show any triglide at one, everything is all 2 wheelers and even the CVO's. I called harley up and they said it is not recongnize by harley for triglides, I ask him why not and he could not answer it, go figure.
All for now Trampas
EBS
I see that your hoses run up and over the air cleaner. You may have trouble with that as there may not be enough pressure to push the oil up and it may block off your air flow. I had that trouble with my freewheeler until I routed the hoses to all flow downward.
Thanks for your feed back,
The factory hoses ran the same way over the filter. I had this same set up on my previous mod on this 2017 with no issues before I moved the catch can further down to the frame.
I have seen simular mods done by others. It seems to work just fine, it is really just a vent. I don't think pressure plays to much into it functioning correctly as a vent.
Also the 107 M8 vents to two diffrent places. Another vent goes to a space in the crankcase. Previous year Harley motors did not do this.
What year was your Freewheeler??
Time will tell.
Ride Safe,
Bill G
All for now Trampas
Thats is news to me and you may be correct. My dealer tells a diffrent story. I talked to them about it just before I did my testing on the stage 1 without a tune being done.
Ride Safe, :)
Bill G
Gerald,
The more I thought about it it made me think why take a chance. So I re-did the lines to go low it was easy enough to do. Why take a chance that it will be an issue on the road. It is just a vent so this way there should be no restriction at all.
See pic's of re-rout to flow downward instead of over the filter. ThumbUp
Thanks again for your feed back on this. :)
Bill G
vent
Gerald,
Bill G
looks good. you will have no problems now for sure.
Looks like you had to drill another hole in air cleaner by the looks of it, basically I think this looks better and it won't have to go uphill so to speak
All for now Trampas
All for now Trampas
Yes, I had to drill another hole but it is on the inside of the air box out of sight. The hose would not squeeze between the filter and the cover coming down the front side so the hole had to be done.
It worked out well this way. The hole also serves as a guide and support for the hoses path. Also the hole does not affect the function or strength of the air box in anyway.
Take Care Friend,
Bill G
Thanks for this write-up. I have been considering the very same idea for my 2012 as I am running the stock air box with a K&N filter with the air box modified for increased air flow. Getting the oil vapor out of the air cleaner is a good idea and my ideas for an EBS are very close to what you did. Great pictures.
Bill G ?
Gerald,
Bill G
Is this 3/8" fuel line you used for routing ? Looks like also 2- 90* elbows and a Tee ? Like this mod. I only have 100 miles on my 17 Tri with no oil yet showing in the filter area. I am surprised to see no drain hole in the plastic filter housing ,looks like water would puddle there. Thanks Doc
Doc,
The tubing is 1/4" I believe. It is some tubing I had laying around from some smog stuff that was removed from a duel sport a few years back. Yes two 90 and a T, also some spring clips.
The tubing needs to fit tight that's why I used the spring clips. When you change the venting from positive pressure to negative pressure with the mod. Any loose fitting hoses will or could weep oil vapor.
I bet if you remove your air filter and look in the throttle body you will see a small puddle of oil in it like in the pic below.
Harley has routed the vapor back in this way for years and has worked to meet EPA requirements. I look at it like this, if you can remove the hot oily vapor from the throttle body without major mods, why not.
If it was a major mod I would have left things alone but it's a pretty simple mod to do. It has has to be better for the motor taking the hot vapor out of the throttle body.
The pic below is of my 2017 trike stock set up at around 800 miles or so. I got the catch can from DK Customs. It seems to be the right size.
Ride Safe, :)
Bill G
Pulled the stock nipple, I see it is 1/4" Sorry.
Correct 1/4" also there is a very small seem at the bottom of the stock air box. I don't think it is air tight.
I suppose this could weep water out but how affective it would be is another thing. Yes, I agree in your other post a weep hole might be a good thing.
The long run of tubing I used is thicker more heavy duty in size but was 1/4". It all fit nice and tight.
Take Care, :)
Bill G
Bill G
Take Care, :)
Bill G
Thanks for the pictures and info on the breather. I still have no oil in the intake dry as a bone but I am doing your mod anyway and drill a weep hole in the air box. I have always vented the breather to ground in years past and it has worked out great for me , Never did it with the stock air box. I like what you did and am going to do it. Thanks Doc
Take Care, :)
Bill G
OK I did your mod,
All 1/4" with barbs on the fittings . Will not come loose. I show a pic of the holes I drilled in the air box the smaller is for a drain may not be needed but hay I was in there
, 1/2"hole for the 1/4" ID fuel line. Plugged the back of the paper filter were the stock line went in. All went well and $28 at Ace they had it all.3 ft of 1/4" fuel line 2 mini clamps 2 90* nipples 1 Tee all with barbs. Thanks Bill G.
These new breathers do not breath as much as the twin cam going by what I felt before the hose install at the breather bolts now it is all out the hose to atmosphere.
I used a rubber plug on the back of the filter to seal the hole. That hose looks sweet...
Bill G
Hey hddocfl, what did you use for a catch can, didn't see any pics of that, I seen where you spent $28 at Ace hardware for parts, don't think they have any catch cans but maybe they do, just curious what you are using for a catch can. I do like this simple set up by the way.
All for now Trampas
All for now Trampas
Trampas,
I got the feeling hddocfl left the line open ended from his rite up. Some guys choose to do that.
I had a fella on another forum tell me the catch can was unnecessary, I disagree. I don't like the line open ended myself.
My reason is the oily vapor can blow back and get on the bottom of your bike over time. This attracts crime and dust that then sticks to the underside of your bike.
The catch can filters the vapor through foam allowing the vapor to go out the top of it clean ( through the little holes around the top).
The oily water vapor sludge stays in the catch can. You just got to service it once in a while. Fast and easy to do.
Maybe hddocfl will chime in on weather he did or did not add a catch can or a filter.
On another note my set up with the catch can is working out great and working flawlessly.
Ride Safe My Friends,
Bill G
All for now Trampas
I ran it right to the atmosphere no catch can, I have done it this way for decades never had a problem the hose extends down low of the frame. Doc
Right now with only 200 miles on this bike there is no oil in the hose and or at the time I did this mod (Thanks Bill.G) there was no oil in the throttle body bone dry. I rode it today and still no oil and breathing good thru the hose about 20" long. My other rides with the same type of breather to ground would always have a drip at the end of the hose, never on the bike. Time will tell if I need a catch can it will get it. Thanks Doc
Trampas,
Bill G
Bill I agree with you, you are like me, keep the underside as clean as the top side
All for now Trampas
Kickstand_Korner
