Radio
Feb 29, 2012
64
12
Lake Placid Fl.
How do I set my radio so it does not come on every time I start the bike ?? The book says it will do whatever it was the last time it ran..Not True on my 2015 Tri. I run most of the time with radio off so I would like to not have to turn it off every time I ride.....
Thanks for the help, Dave
Would also like to know the answer to this.:Shrug:
Upper left fuse "Radio Power" 20 amp > Pull it and see what happens. ;)
I don't know of any other easy way to have it permanently OFF. It is technically a computer which can show diagnostic data and other info from cycle sensors.
Bob :D
I hardly ever use the radio (I do use the Nav) and asked my dealer about it. They thought it always comes on and can not be changed. They made a call to the Moco and confirmed that it is automatic when you start the trike. I turn "on" the switch, do a walk around to check the lights and let the radio "cycle" through the "accept" (don't touch the screen) and it will go back to the HD shield & clock. Then I hit the starter. If I hit the starter before the radio "cycles" through, the radio stays on. When using Nav, I just turn the volume all the way down. Hope this helps.
jkittoe48
