Has anyone with a de-linked braking system, like Roadsmith, re-plumbed the front brakes so the front brake lever engages all the pucks in the front calipers?
If so, how did you do it?
Not a Gold Wing guy but I can relate what I did on my Victory with ABS. I installed a Champion kit which deletes the ABS function. Previously all my brake lines ran to the abs module. Champion uses plugs to fill the spot in abs where the rear is removed. Half way there. I pulled the abs module completely as well as all the brake lines. Re-plumbed the front brakes from master to a T then to the calipers. It can't be that much different for you. Hope this helps.
Interested in what you think this will accomplish??Has anyone with a de-linked braking system, like Roadsmith, re-plumbed the front brakes so the front brake lever engages all the pucks in the front calipers?
IMO, the stopping power of the frt brakes is sufficient after being delinked, front from rear. The only reason for the "other" pucks is the linked system from rear to front.
I'd like to hear from MotorTrike on what works and what doesn't after their conversion?
I understand unlinking the front brake lever to the rear brakes but, I see no need to unlink the rear brake pedal from the front brake????
I have a Roadsmith and am fairly confident the primary reason for de-linking the brakes is that the OEM rear master cylinder does not have the volume requirement to operate the two VW auto calipers installed on the rear wheels plus the front portion of the original system.
The reason is to increase braking power as de-linking makes half the pucks non functional on the front calipers; two on the left and one on the right.
Like I said, an exercise in "what if". :xzqxz:
I would say that RS has decided the rear master cylinder can handle the volume required to operate the two VW auto calipers installed on the rear wheels plus the front portion of the original system, as they now offer a linked brake system on new trike jobs.
I had a Champion kit installed on my 2010 about 4 years ago and asked what if anything did they do to give me full front braking since the front and rear were no longer linked. They explained to me they added a section of brake line that operated the other pistons that would not have been used so all pistons would be used. Looking at it, it's just a short section of tubing that jumps from one side to the other.
So, here's to progress! :clapping:
I have had the pleasure to ride a trike with this brake system & it is so much better than the one's without this system...the new system feels like the two wheeler did when just using the rear brake.
I called RS to follow up and you are partially correct. The rear brake pedal now operates the three front pucks like it used to. HOWEVER, the Seconday Master Cylinder, which is supplied fluid by the rear master cylinder, is deactivated so that none of that fluid goes to the rear brakes like in the original bike. As a matter of fact I was told they actually remove the SMC.
Here's a link to previous discussion I was unaware of. Shame on me for not paying attention.
http://www.triketalk.com/forum/thre...rd-anything-about-the-RS-going-to-links-brake
