unlinking the linked brakes on a 1800 abs
I have just looked at the champion assembly manual were they say to decouple the linked braking system. Does anyone know why this is?
I am wondering if this improves the braking o trikes where there is no advantages having this on three wheels.
I suspect there are other reasons but probably the largest impact on that decision is the availability/choice of calipers. Keeping the linked system requires a three piston caliper set up where the center piston is activated by the bike's front brake circuit. Delinking the brakes simplifies things for the manufacturer and no doubt saves some $$.
Personally, linked or delinked makes not difference in braking power because I use the rear brakes as my primary then follow them up with what ever amount of front brake necessary to do the job. Linked GL1800 brakes have a 70/30 braking ratio. Used by themselves neither front or back can deliver the stopping power needed so why not just learn to do what is most effective right off the get go?? :xszpv::xszpv:
The reason for de-linking the brakes is that most trike mfg. use automotive brakes on the rears and the OEM rear master cylinder doesn't have enough volume to operate both rear and front brakes in the linked system.
I to use the rears then front as needed. Motor Trike at least with mine has them linked. But I do have watch the front left pad a lot closer.
Wore my fronts out in 21K miles.
My rear brakes are not all that sharp. I have never been able to lock them up. Or have the abs work. If you look at the linked brake setup the amount of brake lines is quite incredible compared to unlink. With the addition of an extra disc on a trike the system must have to work very hard. The reason for asking about decoupling them was to see if anyone had found that it improved braking.
I just don't see a reason for a manufacturer to take the trouble of 'de linking them. It isn't an easy job after all.
I have bled the brakes and have no issues with the compression.
I await to see if anyone else has actually done it.
Champion trike owners already have de-linked brakes, according to champion s manual
I await an answer from them concerning this.
Here is my take on the situation. Your Motor Trike will not lock up the rear breaks so you hope delinking them might improve the situation.
First thing I would do is a complete brake bleed. Don't just bleed the rear. I rode a Motor Trike Adventure for nearly 50,000 miles and until I did the full air bleeding those brakes were terrible!
Second thing I'd suggest is practicing rear brake usage as the primary and front as needed. Don't trust the linked system to do for the trike what it would do for two wheels.
Depending on brake pad condition you might consider replacing them. Don't forget to recondition the rotors....
Give your Motor Trike a chance... Do what you can and I expect you will be happier.
First thing I would do is a complete brake bleed. Don't just bleed the rear. I rode a Motor Trike Adventure for nearly 50,000 miles and until I did the full air bleeding those brakes were terrible! Second thing I'd suggest is practicing rear brake usage as the primary and front as needed. Don't trust the linked system to do for the trike what it would do for two wheels.
The trike kit has only done 8000mls. So the pads are like new.
I have completely changed the fluids and although the system has hardened up just slightly it didn't improve the braking.
Relying only on my rear brakes would be a bit risky. It only become positive when I use the front as well. I have never used only my rear brake either on my previous sidecar outfits , solos or trikes. If the road surface is good and in a straight line the front will always win.
I had a trike previously which used floating disc brake from a motor bike , on the rear. It was superb so I do have something to compare it with. It's not the locking up I am seeking, just using that as measure. If the braking is good one knows it is. This trike is not all that hot. Not to sure where the rotors are!
but as the trike is new what ever they are shouldn't be worn or dirty. I do know the pads are moving free.
The size of piston on the solo (REAR) Goldwing is calculated to be used for Five pistons.(that is if there are four piston in the rear) Four on the rear and one on the front. Once the bike is converted it is asked to operate eight on the rear as well at the one in the front. Added to which is the weight of the kit. Bikes gain a lot from having floating and slotted discs and sintered pads. The rear brakes on Motor trike are basic auto discs.
Looking at the job entailed in de-linking the brakes it's no wonder it isn't done often. You can find this on Champion Trikes works manual. http://www.championsidecars.com/uplo...800_indep..pdf
I will first try to change the pads to more efficient ones with possible better discs. The problem there is finding out from motor trike which axle they have used from Ford.
Motor trike are usually excellent and answering enquiries.
EBC Brakes pads offer more efficient pads and discs but I need to know which to order.
Thanks to mhgoldwing for the info.
Thanks to all those kind members who have taken the time to answer. Like having a friend next door.
The trike kit has only done 8000mls. So the pads are like new. I have completely changed the fluids and although the system has hardened up just slightly it didn't improve the braking.
This trike is not all that hot. Not to sure where the rotors are! but as the trike is new what ever they are shouldn't be worn or dirty. I do know the pads are moving free.
I will first try to change the pads to more efficient ones with possible better discs. The problem there is finding out from motor trike which axle they have used from Ford. Motor trike are usually excellent and answering enquiries.
Sounds like you have a plan. We hope you succeed in getting that improvement. We all know how reassuring those good brakes are.
Why would you bother paying the extra money for ABS and then disconnect it??
When looking at Trike kits 8 years ago, I immediately dropped Champion because of the de-linked brakes.
I am very happy with ABS and my Trike stops very good.
I can only say, the linked brakes on my MT work very well, the rears & front will lock up. But as said, I do most of my braking with the rears.
I do not have ABS. In fact, I was told ABS was impossible to make work on a trike kit. The GW ABS brake system only has two sensors (two wheel bike) ... so what do you do with the third wheel's ABS sensor? Which ever wheel you elect to not have ABS would create an unequal braking system.
On the GW's I have serviced the calipers on, I use a vacuum brake bleeder. Removes any air much faster, easier.
I bought the bike , for triking, simply because it was a good deal. It also has navi which again is useless on the 2007 models. I do know that the brakes are not as good as my previous trike which had un-linked brakes and FLOATING discs They were awesome.
Adding the third wheel ( two auto discs) most certainly adds more work for the rear master cylinder to do. It seems though that getting information on how to do it is very thin on the ground, except for Champion trike.
I'll have to admit that I do not fully understand the inner action between the different brake components but I think that before I chose to modify any of them a call to the kit manufacturer would be prudent. Now, if it is a kit designed to be delinked like my Roadsmith is then the path is clear. The installer (dealer of individual) simply follows the directions supplied by Roadsmith. I did mine and had not a single issue. In fact, if anything my brakes are too good. I need better traction to hold them. Had to jump on them pretty good the other day when a vehicle cut me off. Skidded all three tires just a little... :xszpv: :xszpv:
I can't speak specifically to linked brakes but I can regarding abs. On my Champion kit for my Victory Champion recommends in their instructions to plug the two positions for rear brakes on the ABS module. Then ABS becomes non functional. What's the point of ABS on front wheel only? I just pulled the ABS and ran normal brakes. Problem solved.
Hello Extreme 10, I have a 2013 Lehman Monarch ll, LLH with linked brakes on the pedal only (the secondary MC has been disabled). Lehman which is now owned by Champion uses the Champion IRS kit under the Lehman body.
Long story short, the rear brakes suck. I've tried all the recommendations from board members with little success.
I ended up calling Bill Swift at Champion, and he told me without a doubt to de-link the brakes.
Bellow is a follow up from the conversation I had with him (it is from a thread I started about grease fittings on the drive shaft, but I took the opportunity to get his opinion on my brake problem).
"Bazooka, I spoke with Bill at Champion, and he confirmed that my drivehaft has permanently lubricated u-joints.
He also enlightened me about the issue I have with the poor brakes on my Lehman.
He highly recommended that I de-link my rear brakes. This is something that Champion (and other trike kit manufacturers) do as a rule.
I've been contemplated doing this theorizing that the automotive calipers needed all the power that the small Honda master cylinder could provide.
He said that the online install manual for the Champion IRS would show me how to do it. He also said that their parts department could supply me with the few items needed to de-link.
I will definitely take this project on later this winter.
I will post on the site with my results!
Best regards..........Marcel"
Bill agreed that the little (thumb sized) rear MC was too small for the automotive rear calipers on the back and the 2 front calipers.
When you look at how Champion runs the brake line from the rear MC to the tee at the differential for the brakes, they would have you install a 10" hose onto the rear MC then they want you to install a residual pressure valve at the end of the hose. Then you would install a 20" hose from the residual valve to the tee at the differential.
In my case Lehman has installed a residual pressure valve into the tee at the differential, so all I would have to do is run a 36"hose from the rear MC to the existing residual pressure valve.
If you look at what is involved with de-linking the brakes on the rear pedal, it doesn't seem too hard. I figure if I take my time, it will take me 4 hours!.....
ThumbUp
ThumbUp
Red Wing One,
I'm very interested in your discussion with champion regarding de-linking the brakes. I have a lehman kit and it already has a residual valve. I would love to get a set of detailed instructions on how to do this myself. Do you have any docs. showing this?
ThumbUp
Red Wing One,
Hi Durango9, here is a PDF of the installation manual for a 2012 or newer Champion IRS (I'm not sure what year kit you have)
http://www.championsidecars.com/uploads/5/2/6/7/5267613/gl1800_2012-up_indep_kit.pdf
If you look at page 7, I have to assume your Lehman conversion has already disabled the secondary master cylinder so that all you need to do is remove the line that joins the rear brakes to the lower connections on the front calipers.
Page 8 explains how to evacuate the fluid from the system....(note, you only have to evacuate the fluid from the 2 lower bleed valves on the front calipers back to the rear rear calipers and the rear master cylinder.)
The only steps that pertain to the system you need to evacuate are "a" "g"(hook up the vacuum bleeder to the right rear caliper) "h" "i" "j" and "k".
I don't think you need to evacuate the line going to the left rear caliper.
Once you have drained the fluid, you can modify the plumbing on page 9.
Step "a" should already be done. You would do step "b" and step "c".
If you look at step "e" on page 10, you may decide that you want to move this line over, but I doubt it is necessary!
Now all that's left to do is hook up the rear MC to the residual pressure valve and fill and bleed the system.
If you go to page 16 it shows you what to do with the brake line you disconnected from the rear MC. All you need to do is zip tie it to the other 2 lines that were disabled during the conversion.
Now go to the bottom of page 21, were it tells you to install a new 10" line and residual pressure valve.
It then tells you to run a 25" hose from the RPV to the tee at the differential.
If your Lehman conversion is like mine, there already is a RPV at the tee by the differential, so I'm thinking all you would need to do is run a line (approx. 36" long) from the rear MC to the RPV. (I believe the line would need a banjo fitting at each end)
That should complete your plumbing so that all you have to do is fill and bleed you lines from the rear MC to the rear calipers.
If you look at the "Note:" on the "Evacuation of the fluid" on page 8, it tells you to lock the pedal on the rear MC in the engaged position to eliminate the need to bench bleed the MC!!!!!!!
If you don't already have one, you would probably want to buy a vacuum bleeder.
BTW, I haven't done mine yet but I plan on doing it before Spring. Let me know how you make out. (You can PM me with questions)
Best regards, Marcel
Red Wing One
My Lehman Monarch II SA is mounted onto a 2012 GL1800.
The Secondary master is still operational and I have a linked system.
The Champion pdf outlines a de-linked system so I'm not able to follow those instructions. All I really want to do is bleed the rear disc brakes, but I can't find instructions that show that.
I also have a strange looking Residual Pressure value that has 2 brake lines coming into it and 2 braided lines going to the left and right caliper. The Residual Valve also had a bleed fitting which is not even mention in my Lehman docs.
The bottom line is with a bleeder fitting (1) on each of the real calipers and (1) on the residual valve, I really don't know what sequence should be followed realizing the front calipers are also involved in the procedure due to them being linked.
Lehman states that the rear foot pedal operates both the front and rear brakes, but the hand brake lever only operated the front calipers.
No one seems to have a clear one set of documents that outline the front and rear bleeding procedure for my conversion.
Hi Durango9, I'm surprised to hear that you still have the secondary MC hooked up to your rear brakes. If you look at the Lehman Installation Manual for the Monarch II (Solid Axle) below, you will see that Lehman normally disables the secondary MC!
http://www.lehmantrikes.com/assets/...le-installation-instructions-790a0131aaff.pdf
If I were you I'd call Lehman at 1-888-394-3357, and ask them why your trike is still linked from the secondary MC to the rear brakes.
They should be able to inform you about the bleeding procedure providing the conversion was done according to their installation manual.
There are many that seem confused about the SMC and maybe it's me:Coffee:
I thought most capped off the SMC to the rear, leaving the unit on the bike. The rear brakes are still linked to the front and has nothing to do with the SMC.
I think your right about the confusion! Lehman disables the secondary MC by removing the plumbing from it to the rear brakes and anti dive.
They then install a braided line (11" long) from the secondary MC to the anti dive to keep the AD functional!
I am the originator of this thread and am still at a loss as to how to complete the operation of de-linking the brakes- which are terrible on the Adventure Motor trike.
I actually helped with the conversion of the trike and nothing was done to the Honda brake system other than connecting the two rear brakes into the bikes system.
I have the Champion assembly instructions and am wondering if they apply to a trike with the normal set up of the Honda Goldwing (2007). I am also not too clear on the instructions as it mentions a number of times the rear brake line but not which one as the trike has two discs.
Unfortunately I am having to do this myself as there isn't anyone locally who could be trusted to do the work. Oh for a youtube demo?.
I have never likes the linked brake son the solo and they are even worse on a trike.
Hi Extreme10, how's the weather in Spain It will be -9 Celsius where I am in Canada!
It sounds to me like your almost starting from scratch if you want to un-link your brakes.
If you look at my post #20 I have posted the Installation Instruction for the 2012 Lehman Monarch II LLS. I don't know which model and year your instructions are for, but I think they are probably similar.
I've owned a 2002, 2009, and a 2012, and the brakes were the same for all models!
the instructions have 3 basic sections, removal of plumbing, installation of new plumbing and disabling of the ABS ( if you have it).
I expect you still have 2 lines going back to the tee where the trike kit starts. Both those lines will be removed when you do the conversion.
If you study the instruction in the manual, I believe you have enough information to do the job.
If you read my post #17, I explain that Champion will sell you all the parts needed to do the work.
If you are serious about unlinking your brakes, send me a PM and I'll help you all the way through...........Marcel
The final solution!
Well I have finally had the brakes on my Motortrike adventure (2007 1800) de-linked.
In the end I had my trike builder do the work in exchange for the saddle bags I took off the original bike. When the Bike was originally converted to a trike I also worked on the conversion.
Are they any better, Well when I first got it back from the workshop ( I hadn't worked on this change over) The braking had improved but still not what I wanted. There was also too much travel in the brake peddle for my liking. I re bled the rear brakes and although the was no sign of any air coming out of the system the peddle movement had become more to my liking. There had been a new mechanic in the workshop and I fear that he may have done the finishing work on the trike. It is very important to get the correct bleed nipples and the correct order. Only the top two nipples should be bleed. and start with the furthest away from the master cylinder.
The braking had improved some but still not what I wanted as I do pull a trailer on our holiday.
I had research the actual axle that Motortrike have used for the adventure Irs.
This is from a 2002-2005 ford Explorer. The brake pads also come from this same axle.
My next move was to find a better (more cold friction brake pad) EBC make one intended for competition use. Greeenstuff (DP61631). These pads are identical to those used by motor trike. BUT! they are about 0.5 mm too thick. I took the chance and ordered a set for the UK stockest. I then carefully reduced the thickness by scrubbing then on emery cloth on a completely flat surface . checking all the time to make sure that they where level and square. It worked.
I now have a trike with astonishing brakes, something that I have confidence in if I was pulling a trailer .
My final act when I had finished all this work was to use an old racing trick to finally clear all the remaining air from the system , Fine air bubbles can collect in the top of cylinders etc. These are incredibly small fine air bubbles which cannot usually be seen by naked eye. I fasten down the foot brake peddle (you can also do this with the front brake as well) until the peddle is completely solid. Remove the brake fluid reservoir cap and leave it like that for at least over night. Those little devils will be forced back down the line and out through the reservoir. This really does work!
Thanks to all those who have joined in this thread that given advice.
Somewhere in this thread there had been a comment that one trike rider only ever used his back brakes. Although our trikes do have big wheels and tyres (this can be part of the problem of course for our small master cylinder) The front brake is still one of the best in an emergency. If one gets into the habit of just using the rear brake you just may not re-act as you should when the time comes to put all the anchors on. Just my two pennies worth.
I might also add to this...
Get the recall done before you do any of this...
My rear pedal was satisfactory, by that I mean it stopped the trike pretty well.
I got the recall done and I go back a BRICK as a brake pedal, i could if I chose to lock up the rear brakes....
It was THAT big of a difference!!!!!
My rear Master cylinder MUST have been weak
I also have a Motor Trike and my brakes are linked and I have no problems with it. I'm in the process of changing the air bags and just inspected the rear brake pads and they are like new. Since I'm not the original owner I don't know when or if the pads have been changed. I need to inspect the front to see the condition of the front pads which I will do soon.
My GW is about to turn 22K miles.
Bill
Tozbro
