question, fuel tank capacity
dirtdobber
Gone But Never Forgotten
Jul 8, 2011
1,122
126
Sand Mountain, AL
Jim
I have ran the free out of gas twice to check how far i can go in case of need and how much the tank will actually hold.
Both times it held almost the same, 5.55 gallons. I could get 6.1 in my 12 cvo street glide and 5.3 in my 07 ultra. Whats the deal here im wondering. Anyone else check to see what it actually holds?
In 2014 HD change the filler necks. Part of this change is that the fuel gauge is much more accurate than it has ever been. The downside is that it is really a PIA to completely fill it up.
I've found that by rocking it side to side when it is getting close to full will let me put in almost 1/2 of a gallon more after it seems like it is full.
Here's a pic of a recent fill-up I did.
Thank you. Ill do that next time. If i can get it to hold 6 gallons ill be good to go. When im riding I dont like to stop except to get gas.
I got your comfort lift installed today. Impressive.
My FLRT "6 gallon" tank takes 5.5 gallons of gas
At R - 47 miles-to-empty, the yellow 'gas pump' icon illuminated. I monitored my mileage down to R - 8 (miles.) Then the 'information window' changed to 'LO RNG' (Low Fuel Range)
I changed to the odometer display, and drove 8 more miles. At that point, the ECM "thought" that I was out of gas. I pulled over and checked the tank with a wooden dipstick. There was still 1-3/4" on the stick in the bottom of the tank, the 'information window' still displayed 'LO RNG', the yellow 'gas pump' icon was on, and the gas gauge was on "E" I continued to drive.
At 4.8 miles on the odometer, one cylinder cut out, then cut back in. I continued to drive.
At 5.8 miles on the odometer, one cylinder cut out, then cut back in. I continued to drive.
At 6.7 miles on the odometer, the engine stalled and stopped (I was driving 20 MPH at the time, in a line of traffic!) But, when I put the shifter in neutral, pushed the clutch in, and pressed the starter button, it started and ran again.
At that point, I pulled into a gas station and filled up the tank to the brim. By "brim", I meant I filled it up to the filler neck insert. The insert is about 1-5/8" below the absolute top of the tank, for fuel / air expansion.
The tank took 5.511 gallons of gas. The yellow 'gas pump' icon turned off. The R (Range) displayed 192 miles-to-empty.
I ran out on a Dealer Demo Ride on one.....I noticed the Harley Dealership Mechanic did the "Shake Thing" also as He tried to completely fill it up.....:xzqxz:
When I am trying to completely fill the tank, I fill to halfway between the brim of the tank and the filler neck insert, shake side to side. When shaking it side to side it will burp and drop down to well below the filler neck. I repeat that process 3-5 times to get the extra 1/2 gallon in (at that point the gas is at the flat spot of the filler neck and won't burp down any lower).
That makes sense to me. My 05 super glide is the same way.
I have noticed it never goes to full by the guage. I just need to get 180 miles to a tank.I'll be good then. I hate stopping so soon.
Tank lift with deluxe option has zero affect on usable gas. See the pic above, I was still running (not out of gas) when I filled up the tank w/ 6 gallons, and I have a 1.5" tank lift and Deluxe option.
You either had a lot more gas left in your tank, or you did not burp it enough when filling up. :)
Where was your gas gauge needle?
When the count down range comes on,[ Anywhere from 32 to 21] Theres about one gallon left in the tank, Then when the low light goes on [Under12 miles] theres about 1/2 gallon left. Iv'e gone 18 miles on low once.. And it still ran fine.. Which make sense because i get between 34/38 MPG's
Another Burper here. I shake mine 3 to 4 times during a fill up to get max gallons into the tank. I try not to let my tank get too low and the most I have put into it is 5.1 gallons. Shaking is key to a max fill.
I normally turn the handlebars so the wheel is facing opposite of the side I am filling up on. I then use the grip to shake the trike and it seems to rock more.
After reading the suggestion of shaking I went and filled up doing the shake. LOL
Filled up yesterday, 3 miles one way to store. Filled up to the top and the gauge was on full instead of a tad below it. Held .4 gallons with 16 mpg for 6 miles. This tells me I did get more in it, how much, who knows. I'll run it out and see. LOL
My mpg are always low most times because I did not run it out at once for a good test, takes a few days most of the time. If I can get 180 miles to a tank that is good enough. I'm very close now. First test was 162 miles, I then lowered the rear of the tank back to factory. I raised it for wiring but I moved them. second test was 172 miles
Fuel and the Free Wheeler
One thing I notice about mine is it absolutely will not pass a gas station. I don't get near the mileage I got on my Road Glide. I only have 1500 on it so hopefully it will get better.
What kind of fuel mileage are you actually seeing on the road,Chris?
Mine got low mpg at first. At around 2,000 miles it jumped to a lot better mpg. Around 29 to 30 mpg at first then it jumped to 35 to 37 mpg. After the stage one with stock mufflers it went south to 27 mpg. I then changed bafflels, went to fulsac cvo baffles and now getting around 34 mpg. It was running a shade rich.
You will notice a change in power and mpg around 3,000 to 4,000 miles. Yes you will see 2 changes most likely. It will improve even more but it will be very minor. I have my bikes and trikes dyno tuned once and then i have the hp and tq check several times when i make small adjustments. This is how I know of these changes taking place. Every bike I have ever check does the same thing but with different numbers of course
I'm getting 26 or so. Most so far is 28. I routinely got 38 on the glide but of course this one is a trike. I'm new to trikes but the wife has had a street glide trike since 2011, she's always gotten 35 or so.
Get some miles on it, it will get better. I'm sure of that.
After changing baffles on our flrt the mpg went up, so now i am prety sure I'll be good now.
I'm use to 250 miles plus
Get some miles on it, it will get better. I'm sure of that. After changing baffles on our flrt the mpg went up, so now i am prety sure I'll be good now. I'm use to 250 miles plus
Yeah, I think so too. Just gotta put some miles on it. I don't think it is Freewheeler specific, A couple guys I work with just got new Road kings and they aren't getting good mileage either. One had his remapped and dyno and he is pretty happy with it now.
El Cabron
