Any Advantage at All Concerning The DK Custom Comfort Lift On A Freewheeler Trike ???
Mar 5, 2015
474
366
Bakersfield, CA
Bill
Any opinions or experiences would be welcome. I know some of the advantages for the lift kits on the Tri Glides. I would really like Info on the Freewheeler Trikes please.
Thanks in advance to everyone :D
Ride Safe All, :)
Bill G
Ride Safe All, :)
Bill G
Not only will it level it out (see pic below), but more importantly, it will give a smoother ride.
Comfort Lift LINK
Thanks for the feedback, I just placed the order for them.
Kevin does this lift also lighten the steering of the trike a little? I have heard the lifts do this and that might not be a bad thing for the more twisty roads out there.
I am looking forward to the comfort lift and will give feedback down the road.
Ride Safe All, :)
Bill G
Ride Safe All, :)
Bill G
Yes, it will make the steering a bit "quicker", making it take a little less effort to turn. It is not a lot, but most notice it.
We appreciate Your business, and look forward to your feedback!
On second thought after thinking things over a little more and liking the stance and ride of our Freewheeler as it is I have decided to not install the comfort lift for now. :cool:
Thank you everyone again for your input.
Ride Safe All, :)
Bill G
Question for DK Custom
Sent you this question to your web site, no reply, so here goes again. Have a friend just purhased a 2015 TriGlide, he's looking for after market passenger arm rests, thought you might know if they exist???? His passenger doesn't like the Harley arm rests. If mama ain't happy, ain't nobody happy.
Thanks, I see they should be available 8/24/15, but you know how that goes. I'll pass the information along. DK, being Harley specific, I thought they might respond, I appreciate your reply.
http://www.kuryakyn.com/products/486...enger-armrests
We don't know of anyone else...but we have not looked into it much either.
I'm really sorry we did not get back to you. We make every effort to respond to all emails within a few hours, and 99.9% within 24 hours max.
Could you please PM me you email address so I can see what happened to your email...why it was not answered? That way we can learn and improve.
Thanks,
Ride Safe All, :)
Bill G
Just a thought....Have you looked at the stance of you FW when you're sitting on it? They are pretty close to level when unloaded...maybe get a picture taken by someone else when you are on it.
I know I don't care that much about the above, I just like the improved ride.
My e-mail is bikerbillwms@yahoo.com, to problem the add'y being out there, privacy does not exist. Look, not a problem with the late response, just wanted to get the information, now I have it. Hey, maybe I did something wrong on the web site, it happens, no way I can check that.
Thanks,
Thanks Kevin,
Yes I am ok with its stance with me on it.
The bigger deal for me here is I don't want to adjust the headlight angle or tilt it back after the lift. The headlight housing from the factory is aligned perfect to the fork angle with the new front ends design. If tilted back it would change the spacing around the back of the headlight housing at the top and may take away from the looks of the very even spacing around the headlights housing that the Trike has now.
On the Tri Glide this is not an issue as the headlight adjust differently and the tilting would not be noticeable after the adjustment like it would be on the Freewheelers design.
Ride Safe,:)
Bill G
Yeah, I think you must have entered your email in wrong, I just checked and we did not receive any emails from bikerbillwms@yahoo.com
I appreciate that a late response is ok with you. We just like to do better, and always respond quickly.
Sorry we could not be more help.
Thanks Kevin,
Ride Safe,:)
Bill G
I understand that!
Are you sure the headlight does not adjust within the housing, leaving the housing in the same position? I am not sure, but will be looking at a Freewheeler this weekend to find out.
Have a Great 4th!
I understand that!
Have a Great 4th!
Yes pretty sure.
I have had the headlight out to upgrade the bulb, no adjustments that I saw. The service manual shows the headlight housing mounting bolt at the bottom of the housing where it attaches as the tilt adjust if I recall correctly.( I will look again in the Service Manuel tonight after work) If this is the case the issue I mentioned could be an issue depending on how much adjustment was needed. ( I tend to be a little picky about how things look ) I don't think I would like any more tilt back on the headlight housing than it has right now. As stated it is perfectly centered with the spacing around the headlight housing right now.
Ride Safe, :)
Bill G
Yeah, I think you must have entered your email in wrong, I just checked and we did not receive any emails from bikerbillwms@yahoo.com I appreciate that a late response is ok with you. We just like to do better, and always respond quickly. Sorry we could not be more help. Kevin
Whoops, my bad probably, if I had entered everything right, then it should have worked.
I understand that! Are you sure the headlight does not adjust within the housing, leaving the housing in the same position? I am not sure, but will be looking at a Freewheeler this weekend to find out. Have a Great 4th! Kevin
Kevin,
I finally got around to checking the Service Manuel concerning the Freewheelers vertical headlight adjustment to verify what I stated. It adjust as I stated and does not adjust like the Tri Glides vertical headlight adjustment does.
So the Freewheelers vertical adjustment could have the issues I mentioned depending on how much vertical adjustment was needed after the lift.
Ride Safe, :)
Bill G
We normally do not ride at night in my area due to too many 4 legged friends running out in fort of you, deer, cayote's, skunks, bob cats, dogs etc....
We got caught coming home in the dark coming home tonight. I do have the DK comfort lift installed. I do not see a problem. I figured I would need to readjust the head light but the change is so slight it doesn't need adjusting. Flat ground it light up the reflective lines on the road for a 1/2 mile at least, as it seems any way. Lights up the road just fine.
I will not be adjusting my head light for such a slight change. I did think it would be necessary though.
But it isn't that hard to adjust it. I can get my swivel head box end ratchet on the nut easy enough. It will take a bit to get it lose, not much room so it will only turn a couple clicks at a time but it is doable.
Mines done Love it!
Kevin,
Ride Safe, :)
Bill G
You would need a laser level to tell the difference! Very minor! The ride and handling more than makes up for an unnoticeable difference! They should put this on at the factory!
Look at the 2 amber whisky free pics in DK's add??
Just sayin I Like the Lift!
