Brakes and Clutch
Ok trying to find out what I need to get the rear brakes and clutch working. I got a as of bolt on pedal I think the came off a old v star, I think they are stock foot controls, anyone have anyidea what I am going to need? and what is the best set up? it on a rear engine vw trike
Easiest. ..... dune buggy parts. Any vw aftermarket dealer. There is a thread about how good the service is of a few.
Other....make your own mechanical linkage for the clutch.
About the rear brakes..... most (not all) motorcycle master cylinders do not have enough displacement to operate (correctly) automotive brakes.
I'm sure some VW Members will be along soon to give You some Good Advice. I built 2 VW powered Trikes years ago and a few Race Cars. My first Trike used the stock pedals, the second used Old Harley Brake Pedals for the Clutch and Brake. I fitted the clutch cable to one by drilling and using a clevis, and fitted the master cylinder pin from a VW to the Harley Brake Pedal...first Trike used a cut-down Stock Floor Pan, second One I built entirely from Tubing.....ThumbUp
Excellent.
Some good choices. I presume a first build?
Not raked to far for the forks used. Should handle and steer well.
Simple construction do what you know.
I see you don't have any of the tunnel left.
you could rig up the cable pull clutch back onto it or get the dune buggy hydraulic unit.
I like the hyd unit but don't have room for it so mine is all mechanical linkage.
Best and easiest option (not the cheapest) would be get buggy brakes and clutch set up.
The low and mean look is my favorite also. Now a word about rake. The most critical geometry of the front end is trail. You can make any rake angle work, you might effect turn radius but that is just an inconvenience. If you rake the front you will be changing the geometry in a big way. You will have to also change the offset of the yoke or change the entire front end to a springer, leading link, or gurder to be able to correct the change in trail. If you are not up to the construction and the math involved don't do it yet. Ride this one, learn a few things about what you want. Include all the things you learn into the next one or totally rebuild this one.
If you rake the front you will be changing the geometry in aa big way. You will have to also change the offset of the yoke or change the entire front end to a springer, leading link, or gurger to be able to correct the change in trail.
Ok thanks, I have been reading up on rake and trail and how to change it on a goldwing, I want to get it up and running so its useable but also want to make it look good, lol
First of all East Coast, I don't believe the geometry on that pedal assembly is going to work with that master cylinder! You would probably have to have a force of 300 or 400 pounds to be able to push the brakes correctly. Keep in mind that your pedal assembly is made for a mechanical brake system not a hydraulic system.
You might want to look at a complete all in one assembly like this:
http://www.pacificcustoms.com/vw-trike-swinging-pedal-assemblies-short.html
As Deathbysnusnu mentioned in another thread, the bore size will entirely depend on the wheel cylinders and or calipers being used. None the less I think you need to move completely away from the original setup that your trying to use. Just my .02 worth.
Of course I realize that most people are working on a tight budget, god knows I am LOL, but when it comes to brakes I think you need to make sure its safe man.
On the clutch set up, I would convert the clutch to a hydraulic setup like this:
http://www.pacificcustoms.com/cnc320b34.html
Will work much better and you don't have to worry about feeding a cable. You can mount the hydraulic line pretty much where you need to.
Yeppers....
That is what I am talking about. I am out of town vacating with my kids. Didn't do the research for the pics. But exactly.
Check out the buggy parts. They use rear only vw brakes. All the parts that match up for proper operating.
I have an odd set up on mine, but everything about mine is odd.
I like and want the look of forward controls and don't have a lot of money to spend right now
Several things to decide before you buy.
What way are you going to operate the clutch? Cable pull? Mechanical linkage? Hydraulic?
What rear brakes are you going to use?
Stock rear drums?
Beefed up stock type drums?
Disc brakes?
Parking brake?
Now once that is decided, then you can start collecting the parts that fit your purpose.
That is a motorcycle shifter up there. It could possibly be used as a part of a cable pull or mechanical linkage.
That motorcycle master cylinder up there would be fine on pressure but very very low on displacement. May not displace enough to operate drum brake adequately. Possibly ok with disc brakes and a residual pressure valve.
Stock rear drums?
Disc brakes?
Parking brake?
I am just going to use the stock rear drums and brakes for now, maybe later on down the road change over to disc brakes, not reall 100% sure what to do or use for parking brake yet, might just use the stock parking brake system or a hydraulic line lock.
For the clutch I was just thinking of using a pull cable, I like the idea of the hydraulic for the clutch but I think I could use the money else where on the trike for now.
Nothing wrong with a cable pull. Don't last very long with monster clutches. Scary when sitting at a red light with it in gear and clutch pressed just waiting....... and snap and you are headed across the intersection ready or not. But i remiss.... with a stockish clutch no problem just inspect it regularly.
Now unless you are gonna used solid motor/trans mounts you will have to have a flex point. Vw does this with a bowden tube. Use it or the clutch will shake/chatter while engaging.
The rear brakes on a car are only a small part of the stopping power. On a trike the rear is near all the stopping power. Stock vw brakes are sadly weak for stopping by themselves. I would at least put super beetle front slave cylinders on the back with decent condition drums and new quality shoes.
Since you will only be using the rear brakes you will need a single piston/curcuit master cyl. Drum brakes take a good bit of displacement to fill up then build pressure. I personally would not use a motorcycle master on car drums. Go with a buggy/vw single master in the 17mm to 19mm bore size. Make sure your peddle and lever have the travel to push it way down the bore to get your displacement.
Cheapest thing I see.
http://m.ebay.com/itm/311008018755?nav=SEARCH
Excellent points Deathbysnusnu!!!
The master cylinder you linked is pretty much the same as a stock VDub. You should be able to pick one up at NAPA for around the same price as the one linked and have it in a day or two.
You can go to NAPA and order one for a late 60's bug. That would most likely be quicker than going through Ebay.
I can't find anything from a buggy/vw single master in the 17mm to 19mm bore size that looks like forward controls for a bike, I don't real like the look of the pedals hanging down off of the master cylinder, wish I could find something that looks more bikeish lol
That style of master cylinder in the link you put up, would it be able to work with my forward controls somehow?
I have a new master cylinder from a bug somewhere around here only used an old one in the pics because it was the first one I seen
I am not sure if the forward controls would have the leverage enough to apply ample pressure to the master to allow for decent braking. :AGGHH:
I do use a modified motorcycle peddle on my vw master cyl. If you get your ratio and lengths right you can make that work.
Now that is the wrong type of master cyl. But the single unit mounts the same.
Yes I can get a different master cylinder and make up a rod to make it work? Why could I just block off the front brake on a vw bug master cylinder and just use the back brake side of it?
It don't work that way. It has to displace and come up to pressure too.
Sorta like you could block off the gas line and you would use absolutely no gas at all.
It just don't work that way.
ShonaZiemb
