What Trike Kit do I have?
Oct 30, 2014
10
Mystic,CT, USA
I just contacted the guy I bought my trike from to find out what kit I have and he said he thinks it is a "TFK" but he wasn't sure. He did say it was from Pennsylvania. He also said it was a 2007 to a 2010 trike kit. Can anyone tell me what kit I have so I can get some info on it and get some brake pads for it?
Mike
Sounds like a few pictures might be the way to go. Someone I know had a DFT installed by a dealer in Penna, but location doesn't mean much with dealers and installers located in many places. Amazing the previous owner doesn't know what he owned. :Shrug:
Let us know what you find out... ThumbUp
if its a dft you can change brakes easy they are factory Honda brakes.0621141109.jpg is this what you rear end looks like. does it use the factory rear drive.
Thanks everyone for all the input. triwinggirl you might have it, it does look like it. Now I need to investigate just which kit ( if they make different ones ) it is and if I can get maintenance book on it.
Thanks Again
Mike
Thanks Again
Mike
DFT maintenance is very simple. There are 4 grease fittings on each side that should be greased every 4000 miles and the final drive fluid and differential fluid changed about 15-20,000 miles. I however change the diff. and final drive fld. once a yr which is below the recommended mileage. Call Leon at DFT and he will probably send you some instructions.
Thanks Rowdy. Do you have his # and do you think he would have a diagram for the kit?
DFT is a sponsor of this forum. Look on the right side of the screen and scroll down. Click on the ad and it will take you to the website. The 800 contact number is at the bottom. You will not find better customer service than Leon will give. Talk to him about what you need and he will be glad to help.
louisianaJack
