Steering wheel adjustment
Jun 30, 2014
31
3
Elkton, FL
Mike
I tried for weeks to find a reference to this but failed. Someone had directions on how to adjust the linkage so the steering wheel is aligned when driving straight. Mine is at 1 o'clock instead of 3 o'clock.
Thanks so much!
Mike
Between the steering box and the triple tree is an adjustable turnbuckle. The threads are reversed on each end. Loosen the lock nuts on each end and then turn the buckle either one way or the other. Remember to have the steering wheel unlocked with the key. If you have the front wheel straight and do not allow it to move, the steering wheel should move to where you want it. Tighten down the locking nuts and you should be good to go.
Thank you! It worked perfectly!!!!
Mike
trikenbill
