Thank you folks for the clarification. Glad I brought it up.
Thanks Keith appreciate the comments! Fred ThumbUpFred786, we took our long trip recently and we may have had about the same weight including pulling a trailer. We didn't ever bottom out once and it rode very nice. For me, I wouldn't have changed anything on the suspension. Sometimes I anticipated hearing an "ouch" from the backseat when crossing rough areas like I used to on 2 wheels, but didn't happen.
Keith
Tire pressures?
Hi all, Still working out the best tire pressures on my 95' Wing Hannigan conversion. 4 1/2 Steer Lite, Front Tire is Mich Pilot 63H(Rear), Rear Tire Kumho Solus KR21.
Thanks for your experience. Hocky![]()
Re: Tire pressures?
Hocky & All HMS Trike Owners/Riders,
For your and any HMS Trike regardless of Make & Model Bike converted:
40-41 p.s.i. Front-Rear Compound Bias Ply Tire.
28 p.s.i. Rears.
What rake is on the gl1800 180 front end kit, does it come with a fork brace , what air pressure do you run in the tire ??? I happen to see a gl1800 at a show over the weekend & reading WHEELS wright up, I think I need one of these, LAST BUT NOT LEAST DO YOU GIVE A 10% DISCOUNT ON THESE FRONT ENDS TO TRIKE TALK MEMBERS![]()
I called tuesday to order a kit and was told I can not get one unless I have it installed by hannigan or by a dealer ,I have a CSC COBRA, LISTEN to this was told it would have different geometry than a HANNIGAN kit ???????? :xzqxz:Thanks for the question Road Dog ThumbUp
The HMS 180 Wide Front Conversion utilizes a 5.25* increased Steering Angle Triple Tree.
The Fork Brace is an Option ($199) to the Assembly should you or anyone desire one.
The p.s.i. should be kept at 41.
No "Discount" unfortunately but,
Let me know when you place your Order and I'll be sure to include a Collector Edition Hannigan T-Shirt (*estimated Market Value of $50,000) at no additional expense.
*bad inside joke.
*Valid while limited supplies last.
Thanks again for the Post and the questions.
Seriously, let me know when you order one and what size Shirt you want.
Road Dog, maybe I can help. I just had one installed at the factory and watched a lot of the install. I have worked on bikes, cars and farm ecq. all my life and I wouldn't want to tackle this install. Now after watching I would have no problem changing brakes or tires but there is too many variables on an install. As far as the geometry on a CSC, the Honda Goldwing frame is just that, a Goldwing frame that doesn't change. The front neck is NOT cut so the geometry is the same as ANY kit on the market. Charley
Charley was your bike raked before you did the 180 front end? If so what rake did it have ? I had read all of wheels reports on how good the front end is , but did not no he was coming from a unraked trike. How much different is the new front end ? THANKS DANRoad Dog, maybe I can help. I just had one installed at the factory and watched a lot of the install. I have worked on bikes, cars and farm ecq. all my life and I wouldn't want to tackle this install. Now after watching I would have no problem changing brakes or tires but there is too many variables on an install. As far as the geometry on a CSC, the Honda Goldwing frame is just that, a Goldwing frame that doesn't change. The front neck is NOT cut so the geometry is the same as ANY kit on the market. Charley
Lug nuts
What size allen wrench are the lug nuts on a hannigan?
Standard Honda equipment I suppose?
I need to add one to my tool collection.
Thanks!
Re: Lug nuts
A #12 sized metric Allen socket will do the job. Hannigan provides a tool that is that size with a 3/4" hex head and just under 3" long. I believe the reasoning for the hex head is so that one can use a conventional lug wrench. I bought a fold up type at one of the auto parts stores to keep in the trunk along with the tool
Larry
Road Dog & All,
Apologies for the conflicting information. Please call in to 270-753-4256 extension 224 when convenient and we can get everything on the right track and rolling forward quickly and easily.
The Geometry on the front is the same regardless of Manufacturer as accurately pointed out by Charley (Thanks Charley! ThumbUp). The Rear Geometry is obviously quite different. Therefore the Overall Geometry of the Trike Unit is equally as differing accordingly.
However, as far as the HMS 180 Wide Front Conversion is concerned there are no issues with compatibility or applicability. The Value, Merits, and Benefits translate equally to Trikes of all Manufacturers including your CSC.
Regarding the availability of the HMS 180 Wide to you for self-install, given your professed abilities and experience I see no issue personally. We will lay all that to rest when you call as well.
As Charley pointed out, it is more complicated and involved than mere Triple Tree swapping/replacing and Brake Assembly work. A Project of this magnitude and depth can be more daunting and beyond the limitations and capabilities of some (such as myself included). We simply wish to fully and properly inform each and every prospective Client of what is involved in order to allow each to make an informed decision prior to undertaking this Project as most would want and appreciate.
Again, after reading your Post I see no issue and do apologize for the misperceptions.
Look forward to your call and moving onward with providing what you want and need as well as the successful implementation of your HMS 180 Wide Front Upgrade to come.
You are going to Love It ThumbUp
I noticed that in April of this year you received a post regarding Kuryakyn footboards (I assume the boards also included a heel-toe shifter). Three weeks ago I ordered a new Hannigan kit for my '08 GL1800 which also has Kury floorboards. It looks like they will not fit with the foot fairings. My installer suggested eliminating The Kury boards and, in fact, the stock pegs and simply use the foot fairings alone. It appears that the reach to the shifter and rear brake will not be unreasonable. I was wondering if you had any more to report on this issue?
After nearly two years of research, I decided on a Hannigan kit and can't wait for it to be delivered to AMS in New Hampshire and installed.
How does the support bar fasten to the bike that hold the floorboards on my Hannigan trike?
Rufus15, I'm in the process of having the Hannigan kit and '180' installed on my '04 as I type. My installer, Mark Cole, of Cycle Specialties in Portland, Or., took it on a test run "in town" (his son, his chief mechanic, just had to as well) and their comment was "Wow!. I am awaiting completion of the body installation after which Mark (on a not-raining-day-in-Portland[??]) will take it down the Old Columbia Highway and wring it out. I'll post is comments as well as some of my own when the build is completed. At this point in the process, he is very impressed with the mechanicals of the assembly especially the ride quality and 'bump management'. As to the tire, I'd stay with what Hannigan provides unless conversation with them justifies a change.
