Wards Fan
Wondering if you could install without thermostst and have fans always on. I would guess with the thermo it would kick in a few min after start up and stay on anyway.
You can have it both ways..
It does not kick on with the thermo in a few min. and also depends where the thermo is placed on the heads/jug area.
There is a switch that can be turned on and off also on the fans..
If your going to install a set of cooling fans,
Dont waste your money on wards fans. They don't put off much air at all. they wont do you any good going down the hwy. might be ok sitting at a red light. But even then they just do blow much.
Now look at the love jugs they look nice on the bike and will move 2 times the air and thats is what you need on that hot motor.
I totally disagree with your assessment as I have a 2013 trike and the Wards fans put out a ton of air and reduce my cylinder head temps by 25 to 30 degrees. I don't use the thermo switch intentionally as I prefer the manual operation.
The fans do work.
I HAD mine wired to get power when the switch was turned on and I just left the switch on the fans on, so basically they were on all the time. I do agree that they work and move enough air to do the job, but I had dependability issues with them. They are not waterproof and I do ride in the rain. If you read the information that comes with them it basically says to turn them off in wet conditions, guess I wasn't smart enough to do that. I will say I never had any problems getting repairs done free. I also have to say I never completed a single trip (we travel 3-4 weeks at a time) and got home with both of them still functioning, thus the HAD above, I took them off and am running with no fans and doing just as well on oil temps. I am running a fan assisted Jagg oil cooler and I feel that is a better place to spend your money.
Well I do have the fans and they do cool off the heads. I have seen a 280 deg at the head then turn on the fans and watched the temperature of the heads drop So I know they work..I can run them with the thermostat or just turn them off at the switch..
Good Luck
:mad:Don't have a clue where you are coming from, but i have had Wards fans on my 120r motor for about 2 to 3 years and they work awesome. reduces my ET (engine temp) about 30 degrees!! do you sell the "Love Jugs"??
Roger
Roger
I agree 100% ! I have had mine on this year for about 4000mi so far without a problem one. Works very well ! Even in the rain ! The first ones out weren't waterproof, but the new ones are. Two storms & no problem !
FWIW The only time you would need fan assist would be in heavy stop & go traffic or when you are riding below 30 mph on a hot day for an extended period. If your able to go 30 mph or above you should have plenty of air moving over the engine to cool it without any fans.
Put the Wards on last night.Rode 245 miles today. 90-94* all day.Made 5 gas, water, lunch stops. CHT never went above 330*. Without fans I was usually 380-390*. This was combo highway and back roads.I'm happy.
Nope i do not sale the love jugs but i do have a set on my 2013 trike.
And if you think them wards do you any good going down the road you are wrong. Your wasting your time turning them on. Now going through town stop and go setting and waiting on lights to change is were you need a fan.
And the love jugs are the fan to have. I am sorry you got hooked on them wards that kind of blow but you and i both know there not much air flow coming off them.
My love jugs put out at least 2 times more air flow.
So one more thing if you wards are the best in the west does the love jugs put up a little cash reward to out do them you might want get over there to get payed off lol.
I done the same as you before buy some thing and fine out there is a lot better parts out there sorry for your bad luck. And one last thing i never seen a set of them wards on a bike set and run 12 hours. may be you want to be the 1st and show us how good there are.
Show me a person that would let an air cooled motor set and run for 12 hours, (fan or no fan) and I'll show you an idiot! :AGGHH:
First of all,,,, If you let the bike idle for an hour, it won't be any hotter in 12 hours if the fans are doing their job. Done mine for an hour with the temps stable both oil & head temps. True it was only about 73* outside, but the Trike was inside and the air temps went up as the trike ran in a small 12'X 24' room. Head temps went to 211* w/fans, & turn the fans off the temp would go to 280*+. Turn the fans back on & the temp will go down again to around 200*-211*. Oil temps were around 160* at the end of an hour idle. No fans on oil cooler.
On the road in the hills 2-up slow crooked road up & down hills around 30-50mph, up & down, RPM kept around 2500 head temps stayed at 260*+ -. Ambient in the 90*'s, oil temps 250*+-. I also have a Power Vision tuner that I can monitor everything real time.
But then each to their own. It's your money & your motorcycle!
Have a nice day ! Ride Safe !
Everyone has their opinion so chill out on the finger pointing and name calling or I'll shut this thread down. I know the Wards are popular but I also know the Love Juggs are super well built and are much more effective, durable and water resistant than anything else on the market including the Wards, there is simply no arguing that fact. This cooling fan debate reminds me of the age old Harley VS Honda argument threads on other sites. We dont let those sort of arguments build up here and never have. We promote being respectful of each other's choice in bikes and trikes and we hold the same feeling about cooling fans so get civil or your posts will be deleted.
Yes, you can run them with no thermostat. I have a set on my Softail and my 2014 Tri-Glide and had a set on my 2011 Tri-Glide.
I prefer the manual switch, allowing me to turn them on or off at will.
I have not had that experience.
I agree, they are more effective at stop & go, & slow speeds. But I regularly play with them at interstate speeds and see a 10-20 degree drop in Front CHT, even at 70 mph on the Tri-Glide. That is on the front cylinder. Since the rear cylinder does not get as much air when running down the road, I would think (but have not documented it) that the difference would be even greater.
Just to clarify, I took the temps from back of rear jug on right side. Left side is a lot cooler. Took a 125 mile today. 93* outside. Bike runs 50-60* cooler with no more pinging and never had EITMS kick in.Just sayin.
You can take your sympathy for my purchase and place it where the "sun don't shine", as I most certainly do not need your opinion regarding anything on my Trike!! OK??
Roger
The maker of the Wards fans is now saying they should not be run with a thermostat. They should be on all the time. This quote taken off his website:
"Running the system intermittently will expose the fan motors to extreme heat that will likely cause premature failure. "
Jason told me he highly recommends using the thermo. Reason is the fans stay on for a few minutes after engine is shut down. Thermo is 205 on and 155 off. [those numbers might be wrong, but close] CHT will never be 155 when running so the fans will not go off
Meanwhile......Here I am with my Lenale fan and could not be happier with this set up. It has been on my Tri Glide for the last three years and not a single problem with it. Been thru tons of rain and it still works like a champ. I do not use it on the highways, just when we come into towns and start to hit stop lights. I just flip the ACC switch on and when get back on the open road I shut it off. It looks like a factory part and does not cover up the jugs. I have the Harley oil temp gauge and my oil temps have NEVER been past 245. I have the stock oil cooler with NO fan on it, but I did modify it. If it crapped out today, I would buy another one in a heartbeat. :D
The reason this thread went all nuts is because people can't read, and it got off topic. The original poster asked if it was ok to run Ward fans without a thermostat. Not comparing different fans. There are other threads regarding that.
The original question has been answered. Move on folks, let this one drift off into oblivion.
My Bad: But to that question as stated yes you can go with or without auto switch. With that said though, Jason had sent me the newer "Snap Switch" this switch is awesome, it is slightly different than the original "creep switch". I turns the fans on when temp reaches 90° C and back off again when head temp is back to 90° C. This eliminated the multiple fan cycling when bike was turned off. Great improvement.
:Agree: Amen!!
Roger
A thread that got off topic......Like that has never happened before!!:laugh:
I have the snap switch installed just under the heat sensor in the fins in the front cyl head. There is a small pocket there that you can get the snap switch into. The creep switch is larger & won't fit in there. Being in the little pocket it is protected from blowing air.
Mine usually cycle a couple times after shut down. Depends on the engine temp at shutdown. If you want to turn the fans off for whatever reason there is a switch mounted on the fan mounting housing.
Bullet Proof
