Well made an appointment at Larrys Sports Center to have trike tuned, is there anything I need to do or know, I have power vision on 2011 TRI.
Install new HD 6R12 plugs before going to the shop and make sure the clutch is adjusted.
I had a Dyno done to mine after Cam,tuner,exhaust, etc. done before this winter and I didn't put new plugs in. They looked good before I took it to my Tuner Mechanic. Should I replace the plugs since the Dyno or leaved them alone?? or atleast if I do replace them, make sure the Gap on the new plugs be the same that he has on the old?:Coffee:
Plugs should be replaced every 5k miles. The sharp edge of the 6R12 wire when new gives you the best spark. Each time the plug fires it gives up a little metal. Eventually the edge of the plug wire becomes round and you don't get the same spark intensity. Always a good idea to check your gave
I got 9,000 miles on plugs. Time to change. Battery is reading 13.0 out of bike (winter) but is original battery on the 2010 triglide. Change that too, I guess.
Was that after a trickle charge or full charge? Some trickle chargers may not keep it up all the way.
A load test would determine the batteries health. But as you posted its 4yrs old. I would replace it for piece of mind.
